2.1.6 Joystick(MCP3008)
In this project, We’re going to learn how joystick works. We manipulate the Joystick and display the results on the screen.
Schematic Diagram
When the data of joystick is read, there are some differents between axis: data of X and Y axis is analog, which need to use MCP3008 to convert the analog value to digital value. Data of Z axis is digital, so you can directly use the GPIO to read, or you can also use ADC to read.
Experimental Procedures
Step 1: Build the circuit.
Step 3: Run the code.
sudo node joystick-2.js
After the code runs, turn the Joystick, then the corresponding values of x, y, Btn are displayed on screen.
const mcpadc = require('mcp-spi-adc');
// Open channel 1 (X-axis)
const xChannel = mcpadc.openMcp3008(1, { speedHz: 1350000 }, (err) => {
if (err) {
console.error('Failed to open X channel:', err);
process.exit(1);
// Open channel 2 (Y-axis)
const yChannel = mcpadc.openMcp3008(2, { speedHz: 1350000 }, (err) => {
if (err) {
console.error('Failed to open Y channel:', err);
process.exit(1);
// Button input on GPIO22 with pull-up
const btn = new Gpio(22, {
mode: Gpio.INPUT,
pullUpDown: Gpio.PUD_UP,
// Read loop
setInterval(() => {
xChannel.read((errX, xReading) => {
if (errX) {
console.error('X channel read error:', errX);
return;
yChannel.read((errY, yReading) => {
if (errY) {
console.error('Y channel read error:', errY);
return;
const x_val = Math.round(xReading.value * 1023);
const y_val = Math.round(yReading.value * 1023);
const btn_val = btn.digitalRead();
console.log(`x = ${x_val}, y = ${y_val}, btn = ${btn_val}\n`);
}, 100);
Code Explanation
This line imports the mcp-spi-adc module, which allows communication with the MCP3008 ADC using the Raspberry Pi’s hardware SPI interface.
const xChannel = mcpadc.openMcp3008(1, { speedHz: 1350000 }, ...);
const yChannel = mcpadc.openMcp3008(2, { speedHz: 1350000 }, ...);
These lines open MCP3008 analog input channels 1 and 2 for reading joystick X and Y axis signals, respectively. The SPI communication speed is set to 1.35 MHz.
mode: Gpio.INPUT,
Initializes GPIO pin 22 as a digital input with an internal pull-up resistor enabled. This pin is used to read the state of a push button.
setInterval(() => {
xChannel.read(...);
yChannel.read(...);
}, 100);
This function runs every 100 milliseconds. It reads the joystick’s X and Y axis values via MCP3008 channels 1 and 2 using SPI. The floating-point values (range 0.0–1.0) are converted to 10-bit integers (0–1023). It also reads the button state using digitalRead() on GPIO22, returning 0 when pressed and 1 when released. All values are printed to the console.
