TT Motor¶
../_images/tt_motor.jpg
This is a TT DC gearbox motor with a gear ratio of 1:48, it comes with 2 x 200mm wires with 0.1” male connectors that fit into a breadboard. Perfect for plugging into a breadboard or terminal block.
You can power these motors with 3 ~ 6VDC, but of course, they will go a little faster at higher voltages.
Note that these are very basic motors with no built-in encoder, speed control or position feedback. The voltage goes in and the spin comes out. There will be variation from motor to motor, so if you need precise motion, you’ll need a separate feedback system.
Technical Details
  • Rated Voltage: 3~6V
  • Continuous No-Load Current: 150mA +/- 10%
  • Min. Operating Speed (3V): 90+/- 10% RPM
  • Min. Operating Speed (6V): 200+/- 10% RPM
  • Stall Torque (3V): 0.4kg.cm
  • Stall Torque (6V): 0.8kg.cm
  • Gear Ratio: 1:48
  • Body Dimensions: 70 x 22 x 18mm
  • Wires Length: 200mm & 28 AWG
  • Weight: 30.6g
Dimensional Drawing
../_images/motor_size.jpg
Example
