1.3 Motor¶
A motor is a typical digital output device, and it is used in the same way as an LED. However, the motor needs to be driven with a large current, and the large current may damage the main control board such as R3 board. Therefore, an L9110 module is used in this occasion, which is a good helper for the R3 board to control the motor safely.
3 in 1 Starter Kit |
380+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
You can open the file
1.3.turn_the_wheel.inounder the path of3in1-kit\basic_project\1.3.turn_the_wheel.Or copy this code into Arduino IDE.
Or upload the code through the Arduino Web Editor.
