2.1.7 Potentiometer
The ADC function can be used to convert analog signals to digital signals, and in this experiment, ADC0834 is used to get the function involving ADC. Here, we implement this process by using potentiometer. Potentiometer changes the physical quantity – voltage, which is converted by the ADC function.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
Please place the chip by referring to the corresponding position depicted in the picture. Note that the grooves on the chip should be on the left when it is placed.
Step 2: Open the code file
cd ~/raphael-kit/python-pi5
Step 3: Run.
sudo python3 2.1.7_Potentiometer_zero.py
After the code runs, rotate the knob on the potentiometer, the intensity of LED will change accordingly.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import PWMLED
import ADC0834
# Initialize a PWM LED on GPIO pin 22
led = PWMLED(22)
# Set up the ADC0834 module
ADC0834.setup()
Map a value from one range to another.
:param x: The value to be mapped.
:param in_min: The lower bound of the value's current range.
:param in_max: The upper bound of the value's current range.
:param out_min: The lower bound of the value's target range.
:param out_max: The upper bound of the value's target range.
:return: The mapped value.
# Get the current reading from the ADC0834 module
res = ADC0834.getResult()
print('res = %d' % res)
# Map the ADC value to a range suitable for setting LED brightness
R_val = MAP(res, 0, 255, 0, 100)
# Set the LED brightness
led.value = float(R_val / 100)
# Wait for 0.2 seconds before reading again
time.sleep(0.2)
# Graceful exit when 'Ctrl+C' is pressed
led.value = 0 # Turn off the LED
Code Explanation
gpiozerofor PWM LED control,ADC0834for analog-to-digital conversion, andtimefor implementing delays.#!/usr/bin/env python3 from gpiozero import PWMLED import ADC0834 import time
Initialize a PWMLED object connected to GPIO pin 22 and set up the ADC0834 converter.
# Initialize a PWM LED on GPIO pin 22 led = PWMLED(22) # Set up the ADC0834 module ADC0834.setup()
Define a function named
MAPto convert one range of values to another, useful for mapping ADC values to appropriate LED brightness levels.def MAP(x, in_min, in_max, out_min, out_max): return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min
Continuously read the ADC value in a loop, mapping the ADC reading (0-255) to a brightness level (0-100) for the LED. Adjust the LED’s brightness based on this mapped value. Implement a delay of 0.2 seconds for better readability and stability.
try: while True: # Get the current reading from the ADC0834 module res = ADC0834.getResult() print('res = %d' % res) # Map the ADC value to a range suitable for setting LED brightness R_val = MAP(res, 0, 255, 0, 100) # Set the LED brightness led.value = float(R_val / 100) # Wait for 0.2 seconds before reading again time.sleep(0.2) # Graceful exit when 'Ctrl+C' is pressed except KeyboardInterrupt: led.value = 0 # Turn off the LED
