2.1.2 Micro Switch
In this project, we will learn how to use Micro Switch. A Micro Switch is a small, very sensitive switch which requires minimum compression to activate. Because they are reliable and sensitive, micro switches are often used as a safety device.
They are used to prevent doors from closing if something or someone is in the way and other applications similar.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Connect the left pin of the Micro Switch to GPIO17, and two LEDs to pin GPIO22 and GPIO27 respectively. Then when you press and release the move arm of the Micro Switch, you can see the two LEDs light up alternately.
Experimental Procedures
Step 1: Build the circuit.
Step 2: Get into the folder of the code.
cd ~/raphael-kit/python-pi5
Step 3: Run.
sudo python3 2.1.2_MicroSwitch_zero.py
While the code is running, press the moving arm, then the yellow LED lights up; release the moving arm, the red LED turns on.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import LED, Button # Import LED and Button classes from gpiozero
from time import sleep # Import sleep function for delays
# Initialize micro switch on GPIO pin 17 with the pull-up resistor disabled
micro_switch = Button(17, pull_up=False)
# Initialize LED1 connected to GPIO pin 22
led1 = LED(22)
# Initialize LED2 connected to GPIO pin 27
led2 = LED(27)
# Continuously check the state of the micro switch and control LEDs accordingly
if micro_switch.is_pressed: # If the micro switch is pressed
print('LED1 ON') # Print a message to the console
led1.on() # Turn on LED1
led2.off() # Turn off LED2
else: # If the micro switch is not pressed
print(' LED2 ON') # Print a message to the console
led1.off() # Turn off LED1
led2.on() # Turn on LED2
sleep(0.5) # Pause for 0.5 seconds before checking the switch again
# Handle KeyboardInterrupt (Ctrl+C) to exit the loop gracefully
Code Explanation
This line sets the script to run with Python 3. It imports
LEDandButtonfromgpiozerofor controlling GPIO devices, andsleepfromtimefor delays.#!/usr/bin/env python3 from gpiozero import LED, Button # Import LED and Button classes from gpiozero from time import sleep # Import sleep function for delays
Initializes a micro switch connected to GPIO pin 17 with the pull-up resistor disabled, and two LEDs connected to GPIO pins 22 and 27.
# Initialize micro switch on GPIO pin 17 with the pull-up resistor disabled micro_switch = Button(17, pull_up=False) # Initialize LED1 connected to GPIO pin 22 led1 = LED(22) # Initialize LED2 connected to GPIO pin 27 led2 = LED(27)
In the main loop, it checks the state of the micro switch. If pressed, LED1 turns on and LED2 off. If not pressed, LED1 turns off and LED2 on. The loop repeats every 0.5 seconds. Catches a KeyboardInterrupt (like Ctrl+C) to allow for graceful script termination.
try: # Continuously check the state of the micro switch and control LEDs accordingly while True: if micro_switch.is_pressed: # If the micro switch is pressed print('LED1 ON') # Print a message to the console led1.on() # Turn on LED1 led2.off() # Turn off LED2 else: # If the micro switch is not pressed print(' LED2 ON') # Print a message to the console led1.off() # Turn off LED1 led2.on() # Turn on LED2 sleep(0.5) # Pause for 0.5 seconds before checking the switch again except KeyboardInterrupt: # Handle KeyboardInterrupt (Ctrl+C) to exit the loop gracefully pass
