2.1.3 Touch Switch Module
In this project, you will learn about touch switch module. It can replace the traditional kinds of switch with these advantages: convenient operation, fine touch sense, precise control and least mechanical wear.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
Step 2: Change directory.
cd ~/raphael-kit/python-pi5
Step 3: Run.
sudo python3 2.1.3_TouchSwitch_zero.py
While the code is running, the red LED lights up; when you tap on the touch switch module, the yellow LED turns on.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import LED, Button # Import LED and Button classes from gpiozero
from time import sleep # Import sleep for delay
# Initialize touch sensor (Button) on GPIO pin 17, pull-up resistor disabled
touch_sensor = Button(17, pull_up=False) # Suitable for sensors that pull the pin low when pressed
# Initialize LED1 and LED2 connected to GPIO pins 22 and 27 respectively
led1 = LED(22) # LED1 connected to GPIO pin 22
led2 = LED(27) # LED2 connected to GPIO pin 27
# Continuously monitor the state of the touch sensor and control LEDs accordingly
if touch_sensor.is_pressed: # Check if the touch sensor is pressed
print('You touch it!') # Output message indicating sensor activation
led1.off() # Turn off LED1
led2.on() # Turn on LED2
else: # If the sensor is not pressed
led1.on() # Turn on LED1
led2.off() # Turn off LED2
sleep(0.5) # Pause for 0.5 seconds before rechecking the sensor state
# Handle a keyboard interrupt (Ctrl+C) for a clean exit from the loop
Code Explanation
This line sets the script to run with Python 3. It imports
LEDandButtonfromgpiozerofor controlling GPIO devices, andsleepfromtimefor delays.#!/usr/bin/env python3 from gpiozero import LED, Button # Import LED and Button classes from gpiozero from time import sleep # Import sleep for delay
Initializes a touch sensor (as a Button) on GPIO pin 17 with pull-up disabled, and two LEDs on GPIO pins 22 and 27.
# Initialize touch sensor (Button) on GPIO pin 17, pull-up resistor disabled touch_sensor = Button(17, pull_up=False) # Suitable for sensors that pull the pin low when pressed # Initialize LED1 and LED2 connected to GPIO pins 22 and 27 respectively led1 = LED(22) # LED1 connected to GPIO pin 22 led2 = LED(27) # LED2 connected to GPIO pin 27
The main loop checks the state of the touch sensor. When touched, LED2 turns on and LED1 off; when not touched, LED1 is on and LED2 off. The loop repeats every 0.5 seconds. Catches a KeyboardInterrupt (like Ctrl+C) to allow for graceful script termination.
try: # Continuously monitor the state of the touch sensor and control LEDs accordingly while True: if touch_sensor.is_pressed: # Check if the touch sensor is pressed print('You touch it!') # Output message indicating sensor activation led1.off() # Turn off LED1 led2.on() # Turn on LED2 else: # If the sensor is not pressed led1.on() # Turn on LED1 led2.off() # Turn off LED2 sleep(0.5) # Pause for 0.5 seconds before rechecking the sensor state except KeyboardInterrupt: # Handle a keyboard interrupt (Ctrl+C) for a clean exit from the loop pass
