2.1.6 Rotary Encoder Module
In this project, you will learn about Rotary Encoder. A rotary encoder is an electronic switch with a set of regular pulses in strictly timing sequence. When used with IC, it can achieve increment, decrement, page turning and other operations such as mouse scrolling, menu selection, and so on.
../_images/2.1.6_rotary_encoder_list.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Schematic Diagram
../_images/2.1.6_rotary_encoder_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/2.1.6_rotary_encoder_circuit.png
In this example, we can connect the Rotary Encoder pin directly to the Raspberry Pi using a breadboard and 40-pin Cable, connect the GND of the Rotary Encoder to GND, 「+」to 5V, SW to digital GPIO27, DT to digital GPIO18, and CLK to digital GPIO 17.
Step 2: Open the code file.
cd ~/raphael-kit/python-pi5
Step 3: Run.
sudo python3 2.1.6_RotaryEncoder_zero.py
You will see the count on the shell. When you turn the rotary encoder clockwise, the count is increased; when turn it counterclockwise, the count is decreased. If you press the switch on the rotary encoder, the readings will return to zero.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import RotaryEncoder, Button
from time import sleep
# Initialize the rotary encoder and button
encoder = RotaryEncoder(a=17, b=18)  # Rotary Encoder connected to GPIO pins 17 (CLK) and 18 (DT)
button = Button(27)                  # Button connected to GPIO pin 27
global_counter = 0  # Track the rotary encoder's position
def rotary_change():
   """ Update the global counter based on the rotary encoder's rotation. """
   global global_counter
   global_counter += encoder.steps  # Adjust counter based on encoder steps
   encoder.steps = 0  # Reset encoder steps after updating counter
   print('Global Counter =', global_counter)  # Display current counter value
def reset_counter():
   """ Reset the global counter to zero when the button is pressed. """
   global_counter = 0  # Reset the counter
   print('Counter reset')  # Indicate counter reset
# Assign the reset_counter function to button press event
button.when_pressed = reset_counter
   # Monitor rotary encoder continuously and process changes
      rotary_change()  # Handle rotary encoder changes
      sleep(0.1)  # Short delay to reduce CPU load
   # Gracefully handle a keyboard interrupt (Ctrl+C)
Code Analysis
  1. Imports the RotaryEncoder and Button classes from the gpiozero library, and the sleep function for delays.
  2. Initializes the rotary encoder with GPIO pins 17 and 18, and a button on GPIO pin 27.
  3. Declares a global variable global_counter to track the position of the rotary encoder.
  4. Defines a function rotary_change to update the global counter based on the rotary encoder’s rotation.
  5. Defines a function reset_counter to reset the global counter to zero when the button is pressed.
  6. Assigns the reset_counter function to be called when the button is pressed.
  7. In a continuous loop, the script calls rotary_change to handle rotary encoder changes and introduces a short delay to reduce CPU load. Uses a try-except block to handle KeyboardInterrupts gracefully.
