š Ready to explore and create with us? Click [here] and join today!
1.1.7 I2C LCD1602ļ
Introductionļ
LCD1602 is a character type liquid crystal display, which can display 32 (16*2) characters at the same time.
Required Componentsļ
Itās definitely convenient to buy a whole kit, hereās the link:
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramļ
T-Board Name |
physical |
SDA1 |
Pin 3 |
SCL1 |
Pin 5 |
Experimental Proceduresļ
Step 1: Build the circuit.
Step 2: Setup I2C (see I²C Configuration. If you have set I2C, skip this step.)
Step 3: Change directory.
cd ~/raphael-kit/python-pi5
Step 4: Run.
sudo python3 1.1.7_Lcd1602_zero.py
After the code runs, you can see Greetings!, From SunFounder displaying on the LCD.
If you get the error
FileNotFoundError: [Errno 2] No such file or directory: '/dev/i2c-1', you need to refer to I²C Configuration to enable the I2C.If you get
ModuleNotFoundError: No module named 'smbus2'error, please runsudo apt install python3-smbus2.If the error
OSError: [Errno 121] Remote I/O errorappears, it means the module is miswired or the module is broken.If the code and wiring are fine, but the LCD still does not display content, you can turn the potentiometer on the back to increase the contrast.
Warning
If there is an error prompt RuntimeError: Cannot determine SOC peripheral base address, please refer to If gpiozero doesnāt work.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
import LCD1602 # Import module for interfacing with LCD1602
import time # Import module for timing functions
def setup():
# Initialize LCD with I2C address 0x27 and enable backlight
LCD1602.init(0x27, 1)
# Display the message 'Greetings!' at the top-left corner (row 0, column 0)
LCD1602.write(0, 0, 'Greetings!')
# Display the message 'From SunFounder' on the second line (row 1, column 1)
LCD1602.write(1, 1, 'From SunFounder')
time.sleep(2) # Display messages for 2 seconds
setup() # Run the setup function to initialize the LCD and display messages
# Clear the LCD display if a keyboard interruption (e.g., Ctrl+C) occurs
LCD1602.clear()
pass # Proceed with no further action
Code Explanation
This file is an open source file for controlling I2C LCD1602. It allows us to easily use I2C LCD1602.
The function initializes the I2C system with the designated device symbol. The first parameter is the address of the I2C device, which can be detected through the i2cdetect command (see Appendix for details). The address of I2C LCD1602 is generally 0x27.
# Initialize LCD with I2C address 0x27 and enable backlight LCD1602.init(0x27, 1)
LCD1602.writeis used to display messages on the LCD. The first two parameters are row and column positions, and the third is the message. Now you can see āGreetings!! From SunFounderā displayed on the LCD.# Display the message 'Greetings!' at the top-left corner (row 0, column 0) LCD1602.write(0, 0, 'Greetings!') # Display the message 'From SunFounder' on the second line (row 1, column 1) LCD1602.write(1, 1, 'From SunFounder')
