1.1.4 7-segment Display
Let’s try to drive a 7-segment display to show a figure from 0 to 9 and A to F.
../_images/1.1.4_7_segment_list.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
7-segment Display
74HC595
Schematic Diagram
Connect pin ST_CP of 74HC595 to Raspberry Pi GPIO18, SH_CP to GPIO27, DS to GPIO17, parallel output ports to 8 segments of the LED segment display.
Input data in DS pin to shift register when SH_CP (the clock input of the shift register) is at the rising edge, and to the memory register when ST_CP (the clock input of the memory) is at the rising edge.
Then you can control the states of SH_CP and ST_CP via the Raspberry Pi GPIOs to transform serial data input into parallel data output so as to save Raspberry Pi GPIOs and drive the display.
T-Board Name
physical
GPIO17
Pin 11
17
GPIO18
Pin 12
18
GPIO27
Pin 13
27
../_images/1.1.4_7_segment_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/1.1.4_7-Segment_circuit.png
Step 2: Get into the folder of the code.
cd ~/raphael-kit/python-pi5
Step 3: Run.
sudo python3 1.1.4_7-Segment_zero.py
After the code runs, you’ll see the 7-segment display display 0-9, A-F.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect. After confirming that there are no problems, you can use the Copy button to copy the modified code, then open the source code in Terminal via nano cammand and paste it.
from time import sleep
# GPIO pins connected to 74HC595 shift register
SDI = OutputDevice(17)   # Serial Data Input
RCLK = OutputDevice(18)  # Memory Clock Input (Register Clock)
SRCLK = OutputDevice(27) # Shift Register Clock
# Hexadecimal digit codes for a common cathode 7-segment display
segCode = [
    0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d,
    0x07, 0x7f, 0x6f, 0x77, 0x7c, 0x39, 0x5e, 0x79, 0x71
def hc595_shift(data):
    # Shift 8 bits of data into the 74HC595
    for bit in range(8):
        # Set SDI high or low based on data bit
        SDI.value = 0x80 & (data << bit)
        # Trigger shift register clock
        SRCLK.on()
        sleep(0.001)
        SRCLK.off()
    # Latch data to output by triggering memory clock
    RCLK.on()
    sleep(0.001)
    RCLK.off()
def display_all_on():
    # Function to turn all segments on (for common cathode 7-segment display)
    all_on_code = 0x3f
    hc595_shift(all_on_code)
    print("Displaying all segments on")
        # Display each hexadecimal digit on 7-segment display
        for code in segCode:
            hc595_shift(code)  # Shift the code into 74HC595
            # Print the displayed segment code
            print(f"Displaying segCode[{segCode.index(code)}]: 0x{code:02X}")
            sleep(0.5)  # Pause between displaying each digit
    # Gracefully handle script interruption (e.g., Ctrl+C)
Code Explanation
  1. This snippet imports the necessary classes for the project. OutputDevice from gpiozero is used to control hardware components connected to GPIO pins, and sleep from time is for adding delays.
  2. SDI, RCLK, and SRCLK correspond to the Serial Data Input, Memory Clock Input (Register Clock), and Shift Register Clock pins of the 74HC595.
  3. segCode is an array containing hexadecimal codes for each digit to be displayed on the 7-segment display.
    segCode = [
  4. This function shifts 8 bits of data into the 74HC595. It serially inputs each bit into SDI, toggles SRCLK to shift the bit, and uses RCLK to latch the data to the output.
            SRCLK.on()
            sleep(0.001)
            SRCLK.off()
        RCLK.on()
        sleep(0.001)
        RCLK.off()
  5. This function turns all segments of the display on by sending a specific code to hc595_shift.
        all_on_code = 0x3f
  6. In the main loop, each code in segCode is sent to the display in sequence, with a delay between each.
  7. This part of the code gracefully handles script interruption (like Ctrl+C).
