1.1.2 RGB LED
In this project, we will control an RGB LED to flash various colors.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
After connecting the pins of R, G, and B to a current limiting resistor, connect them to the GPIO17, GPIO18, and GPIO27 respectively. The longest pin (GND) of the LED connects to the GND of the Raspberry Pi. When the three pins are given different PWM values, the RGB LED will display different colors.
T-Board Name |
physical |
BCM |
GPIO17 |
Pin 11 |
17 |
GPIO18 |
Pin 12 |
18 |
GPIO27 |
Pin 13 |
27 |
Experimental Procedures
Step 1: Build the circuit.
Step 2: Open the code file.
cd ~/raphael-kit/python-pi5
Step 3: Run.
sudo python3 1.1.2_rgbLed_zero.py
After the code runs, you will see that RGB displays red, green, blue, yellow, pink, and cyan.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import RGBLED
from time import sleep
# Define a list of colors for the RGB LED in RGB format (Red, Green, Blue).
# Each color component ranges from 0 (off) to 1 (full intensity).
COLORS = [(1, 0, 0), (0, 1, 0), (0, 0, 1), (1, 1, 0), (1, 0, 1), (0, 1, 1)]
# Initialize an RGB LED. Connect the red component to GPIO 17, green to GPIO 18, and blue to GPIO 27.
rgb_led = RGBLED(red=17, green=18, blue=27)
# Continuously cycle through the defined colors.
for color in COLORS:
# Set the RGB LED to the current color.
rgb_led.color = color
# Output the current color to the console.
print(f"Color set to: {color}")
# Wait for 1 second before switching to the next color.
sleep(1)
# Handle a KeyboardInterrupt (Ctrl+C) to exit the loop gracefully.
# GPIO cleanup will be managed automatically by GPIO Zero on script termination.
Code Explanation
This imports the
RGBLEDclass from thegpiozerolibrary for controlling an RGB LED, and thetimelibrary for implementing delays in the code.#!/usr/bin/env python3 from gpiozero import RGBLED from time import sleep # Define a list of colors for the RGB LED in RGB format (Red, Green, Blue). # Each color component ranges from 0 (off) to 1 (full intensity).
The
COLORSlist contains tuples representing different colors in RGB format. By assigning different Pulse Width Modulation (PWM) values to each of the R, G, and B pins through thergb_led.colorattribute, the LED can produce a variety of colors. The PWM values range from 0 to 1, where 0 represents no intensity (off) and 1 represents full intensity for each color component.For instance, setting
rgb_led.color = (1, 0, 0)turns the LED red, as it sets full intensity for the red component while keeping green and blue off. Similarly, varying combinations of these values result in different colors. This technique of color mixing through PWM allows for the creation of a wide range of colors on the RGB LED.COLORS = [(1, 0, 0), (0, 1, 0), (0, 0, 1), (1, 1, 0), (1, 0, 1), (0, 1, 1)]
An RGB LED is initialized with its red, green, and blue components connected to GPIO pins 17, 18, and 27, respectively.
# Initialize an RGB LED. Connect the red component to GPIO 17, green to GPIO 18, and blue to GPIO 27. rgb_led = RGBLED(red=17, green=18, blue=27)
The
while True:loop continuously cycles through the colors defined inCOLORS. For each color,rgb_led.color = colorsets the LED to that color, andsleep(1)pauses for 1 second.try: # Continuously cycle through the defined colors. while True: for color in COLORS: # Set the RGB LED to the current color. rgb_led.color = color # Output the current color to the console. print(f"Color set to: {color}") # Wait for 1 second before switching to the next color. sleep(1)
This section gracefully handles a
KeyboardInterrupt(such as pressing Ctrl+C). Thepassstatement is used as a placeholder to indicate no specific action on interruption, as GPIO Zero handles GPIO cleanup automatically.except KeyboardInterrupt: # Handle a KeyboardInterrupt (Ctrl+C) to exit the loop gracefully. # GPIO cleanup will be managed automatically by GPIO Zero on script termination. pass
