1.1.5 4-Digit 7-Segment Display
Next, follow me to try to control the 4-digit 7-segment display.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
T-Board Name |
physical |
BCM |
GPIO17 |
Pin 11 |
17 |
GPIO27 |
Pin 13 |
27 |
GPIO22 |
Pin 15 |
22 |
SPIMOSI |
Pin 19 |
10 |
GPIO18 |
Pin 12 |
18 |
GPIO23 |
Pin 16 |
23 |
GPIO24 |
Pin 18 |
24 |
Experimental Procedures
Step 1: Build the circuit.
cd ~/raphael-kit/python-pi5
Step 3: Run the executable file.
sudo python3 1.1.5_4-Digit_zero.py
After the code runs, the program takes a count, increasing by 1 per second, and the 4 digit display displays the count.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python-pi5. After modifying the code, you can run it directly to see the effect.
import threading
# Define GPIO pins for the 74HC595 shift register
SDI = OutputDevice(24) # Serial Data Input
RCLK = OutputDevice(23) # Register Clock
SRCLK = OutputDevice(18) # Shift Register Clock
# Define GPIO pins for digit selection on the 7-segment display
placePin = [OutputDevice(pin) for pin in (10, 22, 27, 17)]
# Define segment codes for numbers 0-9 for the 7-segment display
counter = 0 # Initialize counter for display
timer1 = 0 # Initialize timer for counter increment
def clearDisplay():
""" Clear the 7-segment display. """
for _ in range(8):
SDI.on()
SRCLK.on()
SRCLK.off()
RCLK.on()
RCLK.off()
def hc595_shift(data):
""" Shift a byte of data to the 74HC595 shift register. """
for i in range(8):
SDI.value = 0x80 & (data << i) # Set SDI high/low based on data bit
SRCLK.on() # Pulse the Shift Register Clock
SRCLK.off()
RCLK.on() # Latch data on the output by pulsing Register Clock
RCLK.off()
def pickDigit(digit):
""" Select a digit for display on the 7-segment display. """
for pin in placePin:
pin.off() # Turn off all digit selection pins
placePin[digit].on() # Turn on the selected digit
def timer():
""" Timer function to increment the counter every second. """
global counter, timer1
timer1 = threading.Timer(1.0, timer) # Reset timer for next increment
timer1.start()
counter += 1 # Increment counter
print("%d" % counter) # Print current counter value
def setup():
""" Setup initial state and start the timer. """
global timer1
timer1 = threading.Timer(1.0, timer) # Initialize and start the timer
timer1.start()
def loop():
""" Main loop to update the 7-segment display with counter value. """
global counter
for i in range(4): # Loop through each digit
clearDisplay() # Clear display before setting new digit
pickDigit(i) # Select digit for display
# Choose the digit of counter to display
digit = (counter // (10 ** i)) % 10
hc595_shift(number[digit]) # Shift digit value to 74HC595
time.sleep(0.001) # Short delay for display stability
def destroy():
""" Cleanup GPIO resources and stop timer on exit. """
global timer1
timer1.cancel() # Stop the timer
for device in [SDI, RCLK, SRCLK] + placePin:
device.close() # Close GPIO devices
setup() # Initialize the setup
loop() # Start the main loop
# Handle script interruption (e.g., Ctrl+C)
destroy() # Cleanup resources on exit
Code Explanation
These four pins control the common anode pins of the four-digit 7-segment displays.
# Define GPIO pins for digit selection on the 7-segment display placePin = [OutputDevice(pin) for pin in (10, 22, 27, 17)]
A segment code array from 0 to 9 in hexadecimal (common anode).
# Define segment codes for numbers 0-9 for the 7-segment display number = (0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90)
Initializes a timer that triggers the
timerfunction every second. This sets up the recurring counter increment.def setup(): """ Setup initial state and start the timer. """ global timer1 timer1 = threading.Timer(1.0, timer) # Initialize and start the timer timer1.start()
After Timer reaches 1.0s, the Timer function is called; add 1 to counter, and the Timer is used again to execute itself repeatedly every second.
def timer(): """ Timer function to increment the counter every second. """ global counter, timer1 timer1 = threading.Timer(1.0, timer) # Reset timer for next increment timer1.start() counter += 1 # Increment counter print("%d" % counter) # Print current counter value
Shifts a byte of data into the 74HC595 shift register, controlling the display segments.
def hc595_shift(data): """ Shift a byte of data to the 74HC595 shift register. """ for i in range(8): SDI.value = 0x80 & (data << i) # Set SDI high/low based on data bit SRCLK.on() # Pulse the Shift Register Clock SRCLK.off() RCLK.on() # Latch data on the output by pulsing Register Clock RCLK.off()
Continuously updates the display with the current counter value, showing each digit sequentially.
def loop(): """ Main loop to update the 7-segment display with counter value. """ global counter while True: for i in range(4): # Loop through each digit clearDisplay() # Clear display before setting new digit pickDigit(i) # Select digit for display digit = (counter // (10 ** i)) % 10 hc595_shift(number[digit]) # Shift digit value to 74HC595 time.sleep(0.001) # Short delay for display stability
Clears the 7-segment display by setting all segments off before displaying the next digit.
def clearDisplay(): """ Clear the 7-segment display. """ for _ in range(8): SDI.on() SRCLK.on() SRCLK.off() RCLK.on() RCLK.off()
Selects which digit of the 7-segment display to activate. Each digit is controlled by a separate GPIO pin.
def pickDigit(digit): """ Select a digit for display on the 7-segment display. """ for pin in placePin: pin.off() # Turn off all digit selection pins placePin[digit].on() # Turn on the selected digit
Properly releases the GPIO resources and stops the timer when the program is interrupted.
except KeyboardInterrupt: # Handle script interruption (e.g., Ctrl+C) destroy() # Cleanup resources on exit
