2.2.4 Reed Switch Moduleο
Introductionο
In this project, we will learn about the reed switch, which is an electrical switch that operates by means of an applied magnetic field.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramο
T-Board Name |
physical |
wiringPi |
BCM |
GPIO17 |
Pin 11 |
0 |
17 |
GPIO27 |
Pin 13 |
27 |
GPIO22 |
Pin 15 |
22 |
Experimental Proceduresο
Step 1: Build the circuit.
Step 2: Change directory.
cd ~/raphael-kit/python/
Step 3: Run.
sudo python3 2.2.4_ReedSwitch.py
The green LED will light up when the code is run. If a magnet is placed close to the reed switch module, the red LED lights up; take away the magnet and the green LED lights up again.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
ReedPin = 17
Gpin = 27
Rpin = 22
def setup():
GPIO.setmode(GPIO.BCM) #
GPIO.setup(Gpin, GPIO.OUT) # Set Green Led Pin mode to output
GPIO.setup(Rpin, GPIO.OUT) # Set Red Led Pin mode to output
GPIO.setup(ReedPin, GPIO.IN, pull_up_down=GPIO.PUD_UP) # Set ReedPin's mode is input, and pull up to high level(3.3V)
GPIO.add_event_detect(ReedPin, GPIO.BOTH, callback=detect, bouncetime=200)
def Led(x):
if x == 0:
GPIO.output(Rpin, 1)
GPIO.output(Gpin, 0)
if x == 1:
GPIO.output(Rpin, 0)
GPIO.output(Gpin, 1)
def detect(self):
Led(GPIO.input(ReedPin))
def loop():
def destroy():
GPIO.output(Gpin, GPIO.HIGH) # Green led on
GPIO.output(Rpin, GPIO.LOW) # Red led off
GPIO.cleanup() # Release resource
setup()
detect()
loop()
except KeyboardInterrupt: # When 'Ctrl+C' is pressed, the child program destroy() will be executed.
destroy()
Code Explanation
ReedPin = 17
Gpin = 27
Rpin = 22
def setup():
Set the GPIO modes to BCM Numbering. ReedPin, Gpin and Rpin connects to the GPIO17, GPIO27 and GPIO22.
GPIO.add_event_detect() is used to add an event that is triggered by a change in the value (level) of ReedPin, at which point the callback function detect() is called.
def Led(x):
if x == 0:
if x == 1:
Define a function Led() to turn the two LEDs on or off. If x=0, the red LED lights up; otherwise, the green LED will be lit.
def detect(self):
In this callback function, the value of the reed switch is used to control the 2 LEDs.
