2.2.2 Thermistor
Just like photoresistor can sense light, thermistor is a temperature sensitive electronic device that can be used for realizing functions of temperature control, such as making a heat alarm.
../_images/list_2.2.2_thermistor.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
Thermistor
ADC0834
Schematic Diagram
../_images/image323.png ../_images/image324.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image202.png
cd ~/raphael-kit/python/
Step 3: Run the executable file
sudo python3 2.2.2_Thermistor.py
With the code run, the thermistor detects ambient temperature which will be printed on the screen once it finishes the program calculation.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
# -*- coding: utf-8 -*-
import RPi.GPIO as GPIO
import ADC0834
import math
def init():
    ADC0834.setup()
def loop():
        Vr = 5 * float(analogVal) / 255
        Rt = 10000 * Vr / (5 - Vr)
        temp = 1/(((math.log(Rt / 10000)) / 3950) + (1 / (273.15+25)))
        Cel = temp - 273.15
        Fah = Cel * 1.8 + 32
        print ('Celsius: %.2f °C  Fahrenheit: %.2f ℉' % (Cel, Fah))
        time.sleep(0.2)
if __name__ == '__main__':
    init()
        loop()
        ADC0834.destroy()
Code Explanation
import math
There is a numerics library which declares a set of functions to compute common mathematical operations and transformations.
This function is used to read the value of the thermistor.
Cel = temp - 273.15
These calculations convert the thermistor values into centigrade degree and Fahrenheit degree.
These two lines of codes are calculating the voltage distribution with the read value analog so as to get Rt (resistance of thermistor).
This code refers to plugging Rt into the formula TK=1/(ln(RT/RN)/B+1/TN) to get Kelvin temperature.
temp = temp - 273.15
Convert Kelvin temperature into centigrade degree.
Convert the centigrade degree into Fahrenheit degree.
Print centigrade degree, Fahrenheit degree and their units on the display.
Phenomenon Picture
../_images/image203.jpeg
