2.2.1 Photoresistorο
Introductionο
Photoresistor is a commonly used component of ambient light intensity in life. It helps the controller to recognize day and night and realize light control functions such as night lamp. This project is very similar to potentiometer, and you might think it changing the voltage to sensing light.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagramο
Experimental Proceduresο
Step 1: Build the circuit.
cd ~/raphael-kit/python/
Step 3: Run the executable file.
sudo python3 2.2.1_Photoresistor.py
When the code is running, the brightness of the LED will change according to the light intensity sensed by the photoresistor.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import ADC0834
LedPin = 22
def setup():
global led_val
GPIO.setmode(GPIO.BCM)
# Set all LedPin's mode to output and initial level to High(3.3v)
ADC0834.setup()
# Set led as pwm channel and frequece to 2KHz
# Set all begin with value 0
led_val.start(0)
def destroy():
# Stop all pwm channel
led_val.stop()
# Release resource
GPIO.cleanup()
def loop():
print ('analog value = %d' % analogVal)
led_val.ChangeDutyCycle(analogVal*100/255)
time.sleep(0.2)
if __name__ == '__main__':
setup()
loop()
destroy()
Code Explanation
def loop():
time.sleep(0.2)
Read the analog value of CH0 of ADC0834. By default, the function
getResult() is used to read the value of CH0, so if you want to read
other channels, please input 1, 2, or 3 into () of the function
getResult(). Next, what you need is to print the value via the print
function. Because the changing element is the duty cycle of LedPin, the
computational formula, analogVal*100/255 is needed to convert analogVal
into percentage. Finally, ChangeDutyCycle() is called to write the
percentage into LedPin.
Phenomenon Pictureο
