2.2.3 DHT-11
In this lesson, you will learn how to connect and read data from a DHT11 temperature and humidity sensor using a Raspberry Pi. You will learn how to set up the sensor, read temperature in both Celsius and Fahrenheit, and obtain humidity readings. This project introduces you to working with external sensors, handling real-time data, and basic exception handling in Python.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic Diagram
Experimental Procedures
Step 1: Build the circuit.
cd ~/raphael-kit/python
Step 3: Run the executable file.
sudo python3 2.2.3_DHT.py
After the code runs, the program will print the temperature and humidity detected by DHT11 on the computer screen.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like raphael-kit/python. After modifying the code, you can run it directly to see the effect.
from gpiozero import OutputDevice, InputDevice
class DHT11():
MAX_DELAY_COUINT = 100
BIT_1_DELAY_COUNT = 10
BITS_LEN = 40
def __init__(self, pin, pull_up=False):
self._pin = pin
self._pull_up = pull_up
def read_data(self):
bit_count = 0
delay_count = 0
bits = ""
# -------------- send start --------------
gpio = OutputDevice(self._pin)
gpio.off()
time.sleep(0.02)
gpio.close()
gpio = InputDevice(self._pin, pull_up=self._pull_up)
# -------------- wait response --------------
while gpio.value == 1:
# -------------- read data --------------
while bit_count < self.BITS_LEN:
while gpio.value == 0:
# st = time.time()
delay_count += 1
# break
if delay_count > self.MAX_DELAY_COUINT:
break
if delay_count > self.BIT_1_DELAY_COUNT:
bits += "1"
bits += "0"
delay_count = 0
bit_count += 1
# -------------- verify --------------
humidity_integer = int(bits[0:8], 2)
humidity_decimal = int(bits[8:16], 2)
temperature_integer = int(bits[16:24], 2)
temperature_decimal = int(bits[24:32], 2)
check_sum = int(bits[32:40], 2)
_sum = humidity_integer + humidity_decimal + temperature_integer + temperature_decimal
# print(bits)
# print(humidity_integer, humidity_decimal, temperature_integer, temperature_decimal)
# print(f'sum:{_sum}, check_sum:{check_sum}')
# print()
if check_sum != _sum:
humidity = 0.0
temperature = 0.0
humidity = float(f'{humidity_integer}.{humidity_decimal}')
temperature = float(f'{temperature_integer}.{temperature_decimal}')
# -------------- return --------------
return humidity, temperature
if __name__ == '__main__':
dht11 = DHT11(17)
humidity, temperature = dht11.read_data()
print(f"{time.time():.3f} temperature:{temperature}°C humidity: {humidity}%")
time.sleep(2)
Code Explanation
bit_count = 0
delay_count = 0
bits = ""
gpio.off()
time.sleep(0.02)
gpio.close()
This function is used to implement the functions of DHT11. It stores the detected data in the bits[] array. DHT11 transmits data of 40 bits at a time. The first 16 bits are related to humidity, the middle 16 bits are related to temperature, and the last eight bits are used for verification. The data format is:
8bit humidity integer data +8bit humidity decimal data +8bit temperature integer data + 8bit temperature decimal data + 8bit check bit.
When the validity is detected via the check bit, the function returns two results: 1. error; 2. humidity and temperature.
humidity = 0.0
temperature = 0.0
For example, if the received date is 00101011(8-bit value of humidity integer) 00000000 (8-bit value of humidity decimal) 00111100 (8-bit value of temperature integer) 00000000 (8-bit value of temperature decimal) 01100111 (check bit)
Calculation:
00101011+00000000+00111100+00000000=01100111.
If the final result is equal to the check bit data, the data transmission is abnormal: return False.
If the final result is equal to the check bit data, the received data is
correct, then there will return humidity and temperature and output
"Humidity =43%,Temperature =60C".
