7.3 Building an Alarm Siren Lamp
In this project, we’ll create an Alarm Siren Lamp using the Raspberry Pi Pico 2 W. This device simulates the flashing lights and siren sound of a police car or emergency vehicle. It’s a fun way to learn about PWM (Pulse Width Modulation), interrupts, and controlling multiple components like LEDs and buzzers.
ITEMS IN THIS KIT
Pico 2 W Starter Kit
450+
Pico 2 W Kit
SN
COMPONENT
QUANTITY
Getting to Know Pico 2 W
Micro USB Cable
Jumper Wires
Several
LED
Transistor
1(S8050)
Resistor
3(1KΩ, 220Ω, 10KΩ)
Passive Buzzer
Capacitor
1(104)
Slide Switch
Understanding the Components
  • Passive Buzzer: Requires an external signal to produce sound. We’ll use PWM to generate varying frequencies, creating a siren effect.
  • LED: Will simulate the flashing light of a siren by changing brightness.
  • Slide Switch: Acts as an on/off switch to control the alarm.
  • NPN Transistor (S8050): Used to drive the buzzer, as the Pico’s GPIO pins cannot supply enough current directly.
  • Resistor and Capacitor: Used to debounce the slide switch, ensuring stable readings.
Schematic
sch_alarm_siren_lamp
  • GP17 is connected to the middle pin of the slider, along with a 10K resistor and a capacitor (filter) in parallel to GND, which allows the slider to output a steady high or low level when toggled to the left or right.
  • As soon as GP15 is high, the NPN transistor conducts, causing the passive buzzer to start sounding. This passive buzzer is programmed to gradually increase in frequency to produce a siren sound.
  • An LED is connected to GP16 and is programmed to periodically change its brightness in order to simulate a siren.
wiring_alarm_siren_lamp
Writing the Code
We’ll write a MicroPython script to control the buzzer and LED based on the position of the slide switch.
  • Open the 7.3_alarm_siren_lamp.py from pico-2w-kit-main/micropython or copy the code into Thonny, then click “Run” or press F5.
  • Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
# Initialize PWM for buzzer and LED
buzzer = machine.PWM(machine.Pin(15))
led = machine.PWM(machine.Pin(16))
led.freq(1000)  # Set LED PWM frequency
# Initialize the slide switch
switch = machine.Pin(17, machine.Pin.IN, machine.Pin.PULL_DOWN)
# Function to map values from one range to another
    # Ensure in_min != in_max to avoid division by zero
    if in_max - in_min == 0:
        return out_min
    return int((x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min)
# Main loop
        if switch.value() == 1:
            # Alarm is ON
            # Increase frequency and brightness
            for i in range(0, 100, 2):
                # Map 'i' to LED brightness and buzzer frequency
                brightness = interval_mapping(i, 0, 100, 0, 65535)
                frequency = interval_mapping(i, 0, 100, 500, 2000)
                # Set LED brightness
                led.duty_u16(brightness)
                # Set buzzer frequency and duty cycle
                buzzer.freq(frequency)
                buzzer.duty_u16(32768)  # 50% duty cycle
                utime.sleep(0.01)
            # Decrease frequency and brightness
            for i in range(100, 0, -2):
                utime.sleep(0.01)
            # Alarm is OFF
            # Turn off LED and buzzer
            led.duty_u16(0)
            buzzer.duty_u16(0)
            utime.sleep(0.1)
    # Clean up
    buzzer.deinit()
    led.deinit()
    print("Program stopped.")
Once the code is running, toggle the slide switch to the ON position. The buzzer should emit a siren sound, and the LED should flash accordingly. Toggle the switch to OFF to stop the alarm.
Understanding the Code
  1. Initialization:
    • buzzer: PWM object on GP15.
    • led: PWM object on GP16, frequency set to 1kHz for smooth brightness control.
    • switch: Input pin on GP17 with an internal pull-down resistor.
  2. Interval Mapping Function:
    Maps a value from one range to another, useful for scaling the loop variable to desired frequency and brightness ranges.
            return out_min
  3. Main Loop:
    • Checks the state of the switch.
    • If the switch is ON (switch.value() == 1):
      • Runs two loops to simulate the siren effect:
      • Increasing frequency and brightness.
      • Decreasing frequency and brightness.
      • The buzzer frequency varies between 500 Hz and 2000 Hz.
      • The LED brightness varies from off to full brightness and back.
          # Alarm is ON
              utime.sleep(0.01)
    • If the switch is OFF: Turns off the LED and buzzer.
          # Alarm is OFF
          led.duty_u16(0)
          buzzer.duty_u16(0)
          utime.sleep(0.1)
    • Exception Handling: Captures a keyboard interrupt (Ctrl+C) to cleanly deinitialize the PWM objects.
          # Clean up
          buzzer.deinit()
          led.deinit()
Experimenting Further
  • Adjusting the Siren Effect:
    • Modify the frequency range in the interval_mapping function to change the pitch.
    • Adjust the delay in the loops (utime.sleep(0.01)) to speed up or slow down the siren cycle.
  • Add More LEDs:
    • Incorporate additional LEDs of different colors to create a more dynamic light show.
    • Use multiple GPIO pins and PWM channels.
  • Motion Activation:
    Replace the slide switch with a motion sensor (e.g., PIR sensor) to trigger the alarm when movement is detected.
  • Remote Control:
    Integrate an IR receiver to control the alarm using a remote control.
Conclusion
You’ve successfully built an Alarm Siren Lamp using the Raspberry Pi Pico 2 W! This project demonstrates how to control multiple components and create interactive effects. It’s a great foundation for more complex projects like security systems, emergency signals, or creative art installations.
