GAME - Escape
This game is called “Escape”. The player’s objective is to tilt the MPU6050 sensor to move a pixel on the LED matrix and attempt to maneuver it through an opening in the matrix border (the exit).
Elite Explorer Kit |
300+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
You can open the file
11_escape_square.inounder the path ofelite-explorer-kit-main\fun_project\11_escape_squaredirectly.Or copy this code into Arduino IDE.
To install the library, use the Arduino Library Manager and search for “Adafruit MPU6050” and install it.
1/*
2 The code utilizes an Arduino Uno and a GY-87 IMU module to create the "Escape" game.
3 The goal is for the player to tilt the MPU6050 sensor, which controls the movement
4 of a pixel on the LED matrix. The objective is to guide the pixel through an opening
5 in the border of the matrix (the exit). Each successful passage through the opening
6 raises the game level.
7
8 Board: Arduino Uno R4
9 Component: GY-87 IMU module
10 Library: https://github.com/adafruit/Adafruit_MPU6050 (Adafruit MPU6050 by Adafruit)
11*/
12
13// Include necessary libraries
14#include "Arduino_LED_Matrix.h"
15#include <Wire.h>
16#include <Adafruit_MPU6050.h>
17#include <Adafruit_Sensor.h>
18
19// Create instances of sensor and matrix
20Adafruit_MPU6050 mpu;
21ArduinoLEDMatrix matrix;
22byte frame[8][12];
23
24int gapStart = 0;
25int side = 0; // 0: top, 1: right, 2: bottom, 3: left
26
27int pixelX = 4; // Initial position of the pixel in the center
28int pixelY = 3;
29int level =0;
30bool pass = false;
31
32unsigned long gapLastUpdate = 0;
33unsigned long pixelLastUpdate = 0;
34
35void setup() {
36 //init matrix
37 matrix.begin();
38 drawSquareWithGap();
39 matrix.loadPixels((uint8_t*)frame, 8 * 12);
40 matrix.renderFrame(0);
41
42 //init mpu6050
43 Serial.begin(9600);
44 if (!mpu.begin()) {
45 Serial.println("Failed to find MPU6050 chip");
46 while (1) {
47 delay(10);
48 }
49 }
50 mpu.setAccelerometerRange(MPU6050_RANGE_2_G);
51}
52
53void loop() {
54 // movePixelBasedOnMPU();
55 // moveGap();
56
57 unsigned long currentMillis = millis();
58
59 if (currentMillis - pixelLastUpdate >= 200) {
60 movePixelBasedOnMPU();
61 checkPixelPosition();
62 pixelLastUpdate = currentMillis;
63 }
64
65 if (currentMillis - gapLastUpdate >= 1020-level*100) {
66 moveGap();
67 gapLastUpdate = currentMillis;
68 }
69
70 matrix.loadPixels((uint8_t*)frame, 8 * 12);
71 matrix.renderFrame(0);
72 if (pass){
73 delay(1500); //delay for show
74 pass=false;
75 resetPixel();
76 }
77}
78
79
80
81
82void drawSquareWithGap() {
83 memset(frame, 0, 8 * 12); // Clear the frame
84
85 for (int i = 0; i < 8; i++) {
86 for (int j = 0; j < 8; j++) {
87 if (i == 0 || i == 7 || j == 0 || j == 7) {
88 frame[i][j] = 1; // Set border pixel
89 }
90 }
91 }
92
93 createGap();
94
95 // Redraw the pixel after drawing the square and gap
96 frame[pixelY][pixelX] = 1;
97}
98
99void createGap() {
100 switch (side) {
101 case 0: // top
102 frame[0][gapStart] = 0;
103 frame[0][gapStart + 1] = 0;
104 // frame[0][gapStart + 2] = 0;
105 break;
106 case 1: // right
107 frame[gapStart][7] = 0;
108 frame[gapStart + 1][7] = 0;
109 // frame[gapStart + 2][7] = 0;
110 break;
111 case 2: // bottom
112 frame[7][7 - gapStart] = 0;
113 frame[7][6 - gapStart] = 0;
114 // frame[7][5 - gapStart] = 0;
115 break;
116 case 3: // left
117 frame[7 - gapStart][0] = 0;
118 frame[6 - gapStart][0] = 0;
119 // frame[5 - gapStart][0] = 0;
120 break;
121 }
122}
123
124void moveGap() {
125 gapStart++;
126
127 if (side == 0 && gapStart > 5) {
128 gapStart = 0;
129 side = 1;
130 } else if (side == 1 && gapStart > 5) {
131 gapStart = 0;
132 side = 2;
133 } else if (side == 2 && gapStart > 5) {
134 gapStart = 0;
135 side = 3;
136 } else if (side == 3 && gapStart > 5) {
137 gapStart = 0;
138 side = 0;
139 }
140
141 drawSquareWithGap(); // Redraw the square with the moved gap
142}
143
144
145void movePixelBasedOnMPU() {
146 sensors_event_t a, g, temp;
147 mpu.getEvent(&a, &g, &temp);
148
149 frame[pixelY][pixelX] = 0; // Clear current pixel
150
151 if (a.acceleration.x > 1.0) {
152 // pixelY++;
153 pixelY--;
154 } else if (a.acceleration.x < -1.0) {
155 // pixelY--;
156 pixelY++;
157 }
158
159 if (a.acceleration.y > 1.0) {
160 pixelX--;
161 } else if (a.acceleration.y < -1.0) {
162 pixelX++;
163 }
164
165 if (pixelX > 7 || pixelX < 0 || pixelY > 7 || pixelY < 0 || frame[pixelY][pixelX] == 1) {
166 resetPixel();
167 } else {
168 frame[pixelY][pixelX] = 1;
169 }
170}
171
172void resetPixel() {
173 pixelX = 4;
174 pixelY = 3;
175 frame[pixelY][pixelX] = 1;
176}
177
178void checkPixelPosition() {
179 bool isOnGap = false;
180
181 // Check if the pixel is on the gap
182 switch (side) {
183 case 0: // top
184 if (pixelY == 0 && pixelX >= gapStart && pixelX <= gapStart + 2) isOnGap = true;
185 break;
186 case 1: // right
187 if (pixelX == 7 && pixelY >= gapStart && pixelY <= gapStart + 2) isOnGap = true;
188 break;
189 case 2: // bottom
190 if (pixelY == 7 && pixelX >= 5 - gapStart && pixelX <= 7 - gapStart) isOnGap = true;
191 break;
192 case 3: // left
193 if (pixelX == 0 && pixelY >= 5 - gapStart && pixelY <= 7 - gapStart) isOnGap = true;
194 break;
195 }
196
197 if (isOnGap) {
198 if (level<=10){ level++;}
199 else {level=0;}
200 pass = true;
201 }
202
203 // Optionally, you can print out the level for debugging
204 // Serial.println("Level: " + String(level));
205}
How it works?
Here’s a detailed explanation of the code:
Library Imports and Global Variables:
Imported libraries include the LED matrix, Wire (for I2C communication), MPU6050 (motion sensor), and
Adafruit_Sensorlibrary. Initialization of MPU6050 and LED matrix objects. Definition of global variables such as pixelX and pixelY (pixel position), gapStart and side (start position of the gap and which side), level (game difficulty level), and more.setup():Initialize the LED matrix and draw the matrix with the gap. Initialize serial communication and check if the MPU6050 sensor is starting correctly, setting its acceleration range to 2g.
loop():Periodically update the position of the pixel based on MPU6050 sensor readings. Periodically move the gap’s position. Load the new pixel layout and render it on the LED matrix. Check if the pixel has passed through the gap. If it has, delay for 1.5 seconds to display the success, increase the game difficulty, and reset the pixel’s position.
Other Functions:
drawSquareWithGap(): Draw an 8x8 border and create a gap within it.createGap(): Create a gap of length 2 on the specified side.moveGap(): Move the gap’s position based on the current side and gapStart, changing the side when necessary.movePixelBasedOnMPU(): Read acceleration data from MPU6050. Move the pixel’s position based on the acceleration data (resetting if the pixel goes out of bounds or into walls).resetPixel(): Reset the pixel’s position to the center of the matrix.checkPixelPosition(): Check if the pixel is on the gap. If it is, increase the game’s difficulty level and set the pass flag to true.
