Digital Dice
This code is designed to simulate a rolling dice using a 74HC595 shift register and a 7-segment digital display. The dice roll simulation is activated by directly shaking the tilt switch. Upon this action, the digital display cycles through random numbers between 1 and 6, simulating the rolling of a dice. After a brief interval, the display stops, showing a random number that signifies the outcome of the dice roll.
Elite Explorer Kit |
300+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
You can open the file
05_digital_dice.inounder the path ofelite-explorer-kit-main\fun_project\05_digital_dicedirectly.Or copy this code into Arduino IDE.
1/*
2 This code simulates a dice roll on a 7-segment display. Shaking the device
3 (tilt switch activation) starts the roll, displaying random numbers rapidly
4 and stopping after a short duration.
6 Board: Arduino Uno R4
7 Component: 7-segment Display with 74HC595 and Tilt Switch
8*/
9
10const int dataPin = 10; // DS of 74HC595
11const int clockPin = 13; // SH_CP of 74HC595
12const int latchPin = 12; // ST_CP of 74HC595
13const int tiltPin = 2; // The pin where the tilt switch is connected
14
15// Byte representation for numbers in a common-cathode 7-segment display
16byte numbers[] = {
17 // 0b00111111, // 0
18 0b00000110, // 1
19 0b01011011, // 2
20 0b01001111, // 3
21 0b01100110, // 4
22 0b01101101, // 5
23 0b01111101, // 6
24 //... Add the values for the rest of the numbers
25};
26
27// State and timing variables
28volatile bool rolling = false;
29unsigned long lastShakeTime = 0;
30
31void setup() {
32 // Initialize pins
33 pinMode(dataPin, OUTPUT);
34 pinMode(clockPin, OUTPUT);
35 pinMode(latchPin, OUTPUT);
36 pinMode(tiltPin, INPUT_PULLUP); // Enable internal pull-up resistor
37
38 // Attach an interrupt to the tiltPin. When the tilt switch is activated, the shakeDetected function will be called
39 attachInterrupt(digitalPinToInterrupt(tiltPin), rollDice, CHANGE);
40}
41
42void loop() {
43 // Check if it's rolling
44 if (rolling) {
45 byte number = random(1, 7); // Generate a random number between 1 and 6
46 displayNumber(number);
47 delay(80); // Delay to make the rolling effect visible
48
49 // Stop rolling after 1 second
50 if ((millis() - lastShakeTime) > 1000) {
51 rolling = false;
52 }
53 }
54}
55
56// Interrupt handler for shake detection
57void rollDice() {
58 if (digitalRead(tiltPin) == LOW) {
59 lastShakeTime = millis(); // Record the time of shake
60 rolling = true; // Start rolling
61 }
62}
63
64// Function to display a number on the 7-segment display
65void displayNumber(byte number) {
66 digitalWrite(latchPin, LOW);
67 shiftOut(dataPin, clockPin, MSBFIRST, numbers[number - 1]);
68 digitalWrite(latchPin, HIGH);
69}
How it works?
Here’s a detailed explanation of the code:
Initialization of variables:
dataPin,clockPin,latchPin: Pins for the 74HC595.buttonPin: The digital pin where the button is connected.numbers[]: An array to store the encoding representing numbers 1 through 6 on a common anode digital tube.Volatile variables:
rolling: This is a volatile variable indicating whether the dice is currently rolling. It’s declared as volatile since it’s accessed both in the interrupt service routine and the main program.
setup():Set the modes for the relevant pins. Set the input mode for the button using the internal pull-up resistor. Assign an interrupt to the button, which calls the rollDice function when the button’s state changes.
loop():It checks if rolling is true. If it is, it continues to display a random number between 1 and 6. If the button has been pressed for more than 500 milliseconds, the rolling stops.
rollDice():This is the interrupt service routine for the button. It checks if the button is pressed (low level). If it is, the current time is recorded and the rolling begins.
displayNumber():This function displays a number on the digital tube. It sends the number to the digital tube through the 74HC595 shift register.
