Fruit Piano
This project is a simple fruit piano that reads input from an MPR121 touch sensor and plays music through a DAC. In other words, we’ve turned fruits into a keyboard, allowing you to play music by simply touching them.
Elite Explorer Kit |
300+ |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Schematic
You can open the file
02_fruit_piano.inounder the path ofelite-explorer-kit-main\fun_project\02_fruit_pianodirectly.Or copy this code into Arduino IDE.
To install the library, use the Arduino Library Manager and search for “Adafruit MPR121” and install it.
How it works?
Here’s a step-by-step explanation of the code:
Library and Object Initialization:
Import the necessary libraries:
Wirelibrary (for I2C communication),Adafruit_MPR121library (for driving the MPR121),analogWavelibrary (for generating analog waveforms), andpitches.h(which defines the frequencies of notes). Create instances ofAdafruit_MPR121andanalogWaveobjects. Define a notes array to store the note corresponding to each touch channel.setup():Initialize Serial communication and wait for it to start. Check and initialize the MPR121; if not found, print an error message on the serial monitor and halt execution. Initialize the
analogWaveobject and set the initial sine wave frequency to 10Hz.loop():Read the currently touched channels of the MPR121. Iterate through all channels, check which one is touched, and play the corresponding note. Add a small delay between each iteration.
Play Note
playNote():The
playNotefunction takes anoteparameter and sets the DAC frequency to play the corresponding note. Delay for a period to play the note. Stop playing the note.
