HueDial
This example controls the color of an RGB LED based on the position of a rotary knob. Different positions of the knob correspond to different HUE values, which are then translated into RGB color values, resulting in a color change for the RGB LED.
ITEMS IN THIS KIT
Elite Explorer Kit
300+
Elite Explorer Kit
COMPONENT INTRODUCTION
PURCHASE LINK
Arduino Uno R4 WiFi
Jumper Wires
Resistor
RGB LED
Potentiometer
../_images/03_hue_dial_bb.png
Schematic
../_images/03_hue_schematic.png
  • You can open the file 03_huedial.ino under the path of elite-explorer-kit-main\fun_project\03_huedial directly.
03_HueDial.ino
 1/*
 2  This code controls an RGB LED using a potentiometer
 3  to change the hue of the color.
 5  Board: Arduino Uno R4
 6  Component: RGB LED and Potentiometer
 7*/
 8
 9// Define RGB LED pins
10const int redPin = 12;    // Red channel
11const int greenPin = 10;  // Green channel
12const int bluePin = 9;    // Blue channel
13
14// Define the pin for the knob
15const int knobPin = A0;
16
17void setup() {
18  // Initialize RGB LED pins as outputs
19  pinMode(redPin, OUTPUT);
20  pinMode(greenPin, OUTPUT);
21  pinMode(bluePin, OUTPUT);
22}
23
24void loop() {
25  // Read the value of the knob
26  int knobValue = analogRead(knobPin);
27
28  // Normalize the knob value to the range 0-1
29  float hueValue = (float)knobValue / 1023.0;
30
31  // Convert the normalized value to a HUE value (0-360)
32  int hue = (int)(hueValue * 360);
33
34  // Convert the HUE value to RGB values
35  int red, green, blue;
36  HUEtoRGB(hue, &red, &green, &blue);
37
38  // Update the RGB LED with the new color values
39  setColor(red, green, blue);
40}
41
42// Function to set the RGB LED color
43void setColor(int red, int green, int blue) {
44  analogWrite(redPin, red);
45  analogWrite(greenPin, green);
46  analogWrite(bluePin, blue);
47}
48
49// Function to convert a hue value to RGB values
50void HUEtoRGB(int hue, int* red, int* green, int* blue) {
51  float h = (float)hue / 60.0;
52  float c = 1.0;
53  float x = c * (1.0 - fabs(fmod(h, 2.0) - 1.0));
54  float r, g, b;
55  if (h < 1.0) {
56    r = c;
57    g = x;
58    b = 0;
59  } else if (h < 2.0) {
60    r = x;
61    g = c;
62    b = 0;
63  } else if (h < 3.0) {
64    r = 0;
65    g = c;
66    b = x;
67  } else if (h < 4.0) {
68    r = 0;
69    g = x;
70    b = c;
71  } else if (h < 5.0) {
72    r = x;
73    g = 0;
74    b = c;
75  } else {
76    r = c;
77    g = 0;
78    b = x;
79  }
80  float m = 1.0 - c;
81  *red = (int)((r + m) * 255);
82  *green = (int)((g + m) * 255);
83  *blue = (int)((b + m) * 255);
84}
How it works?
Here’s a detailed explanation of the code:
  1. Global Variable Definitions:
    redPin, greenPin, and bluePin: These define the PWM pins connected to the red, green, and blue LEDs, respectively. KNOB_PIN: Defines the analog input pin connected to the rotary knob.
  2. setup():
    Set the pins for the RGB LED as output. By default, analog pins are set as inputs, so there’s no need to set the input mode for the knob’s pin.
  3. loop():
    Read the value of the rotary knob. This value ranges from 0 to 1023. Normalize the knob’s value to a range of 0-1. Convert the normalized value to a HUE value ranging from 0-360. Convert the HUE value to RGB values. Update the LED’s color using these RGB values.
  4. setColor():
    Set the appropriate PWM values for each LED pin using the analogWrite() function to set the color of the RGB LED.
  5. HUEtoRGB():
    This function converts HUE values to RGB values using the HSL to RGB conversion method but focuses only on the HUE component, keeping saturation and brightness at 100%. The algorithm is divided into 6 stages, each covering 60 degrees. It calculates RGB values for each HUE stage and then scales these values to a range of 0-255, which is the expected range for the analogWrite() function.
