4-Digit 7-Segment Display
4-Digit 7-segment display consists of four 7- segment displays working together.
../_images/4-digit-sche.png
The 4-digtal 7-segment display works independently. It uses the principle of human visual persistence to quickly display the characters of each 7-segment in a loop to form continuous strings.
For example, when “1234” is displayed on the display, “1” is displayed on the first 7-segment, and “234” is not displayed. After a period of time, the second 7-segment shows “2”, the 1st 3th 4th of 7-segment does not show, and so on, the four digital display show in turn. This process is very short (typically 5ms), and because of the optical afterglow effect and the principle of visual residue, we can see four characters at the same time.
../_images/image78.png
Display Codes
To help you get to know how 7-segment displays(Common Cathode) display Numbers, we have drawn the following table. Numbers are the number 0-F displayed on the 7-segment display; (DP) GFEDCBA refers to the corresponding LED set to 0 or 1, For example, 00111111 means that DP and G are set to 0, while others are set to 1. Therefore, the number 0 is displayed on the 7-segment display, while HEX Code corresponds to hexadecimal number.
Glyph Code
Numbers
Binary Code
Hex Code
0
00111111
0x3f
0x06
0x5b
0x4f
0x66
0x6d
0x7d
7
00000111
0x07
8
01111111
0x7f
9
01101111
0x6f
A
01110111
0x77
B
01111100
0x7c
C
00111001
0x39
D
01011110
0x5e
E
01111001
0x79
F
01110001
0x71
Example
