MPR121
3.3V: Power supply
IRQ: Open Collector Interrupt Output Pin, active low
SCL: I2C Clock
SDA: I2C Data
ADD: I2C Address Select Input Pin. Connect the ADDR pin to the VSS, VDD, SDA or SCL line, the resulting I2C addresses are 0x5A, 0x5B, 0x5C and 0x5D respectively
GND: Ground
0~11: Electrode 0~11, electrode is a touch sensor. Typically, electrodes can just be some piece of metal, or a wire. But some times depending on the length of our wire, or the material the electrode is on, it can make triggering the sensor difficult. For this reason, the MPR121 allows you to configure what is needed to trigger and untrigger an electrode.
MPR121 OVERVIEW
The MPR121 is the second generation capacitive touch sensor controller after the initial release of the MPR03x series devices. The MPR121 features increased internal intelligence, some of the major additions include an increased electrode count, a hardware configurable I2C address, an expanded filtering system with debounce, and completely independent electrodes with auto-configuration built in. The device also features a 13th simulated sensing channel dedicated for near proximity detection using the multiplexed sensing inputs.
Features
- Low power operation
1.71 V to 3.6 V supply operation
29 μA supply current at 16 ms sampling interval period
3 μA Stop mode current
- 12 capacitance sensing inputs
8 inputs are multifunctional for LED driver and GPIO
- Complete touch detection
Auto-configuration for each sensing input
Auto-calibration for each sensing input
Touch/release threshold and debounce for touch detection
I2C interface, with Interrupt output
3 mm x 3 mm x 0.65 mm 20 lead QFN package
-40°C to +85°C operating temperature range
Example
2.24 MPR121 Module (Arduino Project)
