Say Something
In this section, you’ll learn how to convert text into speech and have Robot HAT speak it aloud.
Steps
  1. We retrieve text from the command line to enable Robot HAT to articulate it. To achieve this, save the following code as a .py file, such as tts.py.
    import sys
    from robot_hat import TTS
    # Check if there are enough command line arguments
    if len(sys.argv) > 1:
        text_to_say = sys.argv[1]  # Get the first argument passed from the command line
        text_to_say = "Hello SunFounder"  # Default text if no arguments are provided
    # Initialize the TTS class
    tts = TTS(lang='en-US')
    # Read the text
    tts.say(text_to_say)
    # Display all supported languages
    print(tts.supported_lang())
  2. To make Robot HAT vocalize a specific sentence, you can use the following command: sudo python3 tts.py "any text" - simply replace "any text" with the desired phrase.
