Hardware Introduction
Pinout
_images/robot_hat_pinout.png
Power Port
  • 6.0V-8.4V XH2.54 3pin power input.
  • Powering the Raspberry Pi and Robot HAT at the same time.
Power Switch
  • Turn on/off the power of the robot HAT.
Type-C USB Port
  • Insert the Type-C cable to charge the battery.
  • At the same time, the charging indicator lights up in red color.
  • When the battery is fully charged, the charging indicator turns off.
  • If the USB cable is still plugged in about 4 hours after it is fully charged, the charging indicator will blink to prompt.
Digital Pin
ADC Pin
PWM Pin
Left/Right Motor Port
  • 2-channel XH2.54 motor ports.
  • Pin: Motor Port.
  • API: module motor, 1 for left motor port, 2 for right motor port.
I2C Pin and I2C Port
  • I2C Pin: P2.54 4-pin interface.
  • I2C Port: SH1.0 4-pin interface, which is compatible with QWIIC and STEMMA QT.
  • These I2C interfaces are connected to the Raspberry Pi’s I2C interface via GPIO2 (SDA) and GPIO3 (SCL).
  • Pin: I2C.
  • API: class I2C.
SPI Pin
  • P2.54 7-pin SPI interface.
  • Pin: SPI.
UART Pin
  • P2.54 4-pin interface.
  • Pin: UART.
RST Button
  • The RST button, when using Ezblock, serves as a button to restart the Ezblock program.
  • If not using Ezblock, the RST button does not have a predefined function and can be fully customized according to your needs.
  • Pin: Buttons.
  • API: class Pin
USR Button
  • The functions of USR Button can be set by your programming. (Pressing down leads to a input “0”; releasing produces a input “1”. )
  • API: class Pin, you can use Pin("SW") to define it.
  • Pin: Buttons.
Battery Indicator
  • Two LEDs light up when the voltage is higher than 7.6V.
  • One LED lights up in the 7.15V to 7.6V range.
  • Below 7.15V, both LEDs turn off.
  • Battery Level Indicator.
Speaker and Speaker Port
  • Speaker: This is a 2030 audio chamber speaker.
  • Speaker Port: The Robot HAT is equipped with onboard I2S audio output, along with a 2030 audio chamber speaker, providing a mono sound output.
  • Pin: Speaker and Speaker Port.
  • API: class Music
Pin Mapping
Raspberry Pi IO
Robot Hat V4
Raspberry Pi
Raspberry Pi
Robot Hat V4
NC
3V3
5V
5V
SDA
SDA
5V
5V
SCL
SCL
GND
GND
D1
GPIO4
TXD
TXD
GND
GND
RXD
RXD
D0
GPIO17
GPIO18
I2S BCLK
D2
GPIO27
GND
GND
D3
GPIO22
GPIO23
MOTOR 1 DIR
NC
3V3
GPIO24
MOTOR 2 DIR
SPI MOSI
MOSI
GND
GND
SPI MISO
MISO
GPIO25
USR BUTTON
SPI SCLK
SCLK
CE0
SPI CE0
GND
GND
CE1
NC
NC
ID_SD
ID_SC
NC
MCU Reset
GPIO5
GND
GND
(SPI)BSY
GPIO6
GPIO12
Board Identifier 2
Board Identifier 1
GPIO13
GND
GND
I2S LRCLK
GPIO19
GPIO16
RST BUTTON
USER LED
GPIO26
GPIO20
NC
GND
GND
GPIO21
I2S SDATA
Digital IO
Robot HAT has 4 sets of P2.54 3Pin digital pins.
_images/digitalio.png
Digital IO
Robot Hat V4
Raspberry Pi
D0
GPIO17
D1
GPIO4
D2
GPIO27
D3
GPIO22
ADC
_images/adcpin.png
The Robot HAT features four sets of 3Pin ADC (Analog to Digital Converter) pins, each spaced 2.54mm apart. These pins operate at a 3.3V power supply. The ADC function, offering 12-bit precision, is facilitated by an onboard microcontroller. Detailed instructions for reading ADC values are provided in the On-Board MCU section.
_images/btradc.png
Also, ADC channel A4 is connected to the battery through a voltage divider using resistors, which will be used to measure the battery voltage to estimate the approximate battery charge.
The voltage divider ratio is 20K/10K, so:
  • A4 voltage (Va4) = value_A4 / 4095.0 * 3.3
  • Battery voltage (Vbat) = Va4*3
  • Battery voltage (Vbat) = value_A4 / 4095.0 * 3.3 * 3
PWM
_images/pwmpin.png
Robot HAT has 4 sets of 3Pin PWM pins, each spaced 2.54mm apart, and the power supply is 5V. The method of using the PWM is described in detail in On-Board MCU.
PWM13 & 14 channels are used for motor drive.
I2C
_images/i2cpin.png
The Robot HAT has two I2C interfaces. One is the P2.54 4-pin interface, and the other is the SH1.0 4-pin interface, which is compatible with QWIIC and STEMMA QT. These I2C interfaces are connected to the Raspberry Pi’s I2C interface via GPIO2 (SDA) and GPIO3 (SCL). The board also features an On-Board MCU, and the two signal lines have 10K pull-up resistors.
SPI
_images/spipin.png
The SPI interface of the Robot HAT is a 7-pin P2.54 interface. It connects to the SPI interface of the Raspberry Pi and includes an additional I/O pin that can be used for purposes such as interrupts or resets.
SPI
Robot Hat V4
Raspberry Pi
BSY
GPIO6
CS
CE0(GPIO8)
SCK
SCLK(GPIO11)
MI
MISO(GPIO9)
MO
MOSI(GPIO10)
3V3
3.3V Power
GND
Ground
UART
_images/uartpin.png
The UART interface of the Robot HAT is a 4-pin P2.54 interface. It connects to the Raspberry Pi’s GPIO14 (TXD) and GPIO15 (RXD) pins.
Buttons
The Robot HAT comes with 1 LED and 2 buttons, all directly connected to the Raspberry Pi’s GPIO pins. The RST button, when using Ezblock, serves as a button to restart the Ezblock program. If not using Ezblock, the RST button does not have a predefined function and can be fully customized according to your needs.
LED & Button
Robot Hat V4
Raspberry Pi
LED
GPIO26
USR
GPIO25
RST
GPIO16
I2S
I2S
Raspberry Pi
LRCLK
GPIO19
BCLK
GPIO18
SDATA
GPIO21
Motor Port
The motor driver of the Robot HAT supports 2 channels and can be controlled using 2 digital signals for direction and 2 PWM signals for speed control.
Motor Driver
Motor
IO
Motor1 Dir
GPIO23
Motor1 Power
PWM13
Motor2 Dir
GPIO24
Motor2 Power
PWM12
The battery level indicator on the Robot HAT monitors the battery voltage using a voltage divider method and serves as a reference for estimating the battery level. The relationship between the LED and voltage is as follows:
Battery Level
LED Battery
Total Voltage
2 LEDs on
Greater than 7.6V
1 LED on
Greater than 7.15V
Both LEDs off
Less than 7.15V
When any one of the batteries reaches or exceeds 4.1V while the others are below that threshold, the charging current of that specific battery will be reduced.
