1.9 Drummingο
In this project, we play the drum with a touch switch module.
Required Componentsο
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Build the Circuitο
Load the Code and See What Happensο
Load the code file (1.9_drumming.sb3) to Scratch 3.
When you tap on the touch switch module, you will hear the sound of drums coming from the speaker.
Tips on Spriteο
Delete the default sprite, then find the Drum-snare sprite and add it, and change the size to 200.
Scratch has a Music extension to play instruments and drums, now add it via the Add Extension button.
Tips on Codesο
When pin17 is low (not tapped on the touch switch module), switch the Drum-snare sprite costume to drum-snare-a.
When you tap on the touch switch module, gpio17 is low. At this point, the Drum-snare sprite costume is switched to drum-snare-b and the drum sound played on speaker.
