1.11 Repelling locusts
Today, we will use IR obstacle avoidance module, Raspberry Pi and Scratch to make a locust repelling game.
Place your hand in front of the obstacle avoidance module and you will see the locusts being chased away.
Raphael Kit |
337 |
COMPONENT INTRODUCTION |
PURCHASE LINK |
Build the Circuit
Load the Code and See What Happens
Load the code file (1.11_repelling_locusts.sb3) to Scratch 3.
Tips on Sprite
Select Sprite1 and click Costumes in the top left corner; upload locust1.png, locust1.png and locust3.png from the ~/raphael-kit/scratch/picture path via the Upload Costume button; delete the default 2 costumes, and rename the sprite to locust.
Tips on Codes
When the IR obstacle avoidance module does not detect an obstacle (no hand is placed in front of the probe), the gpio is high.
When gpio17 is high (no obstacles go in front of the IR obstacle avoidance module), switch the locust sprite’s costume to locust1 (locusts gather in wheat). Conversely when gpio17 is low (put your hand in front of the IR obstacle avoidance module), switch the locust sprite’s costume to locust2 (expel locusts), then switch the locust sprite’s costume to locust3 (locusts are completely expelled) after 0.5s.
