1.12 Water Lamp
Today, we will use LED Bar Graph, Raspberry Pi and scratch to make a Water Lamp.
The LED Bar Graph will light up in order with the direction of the arrows on the stage.
../_images/1.12_header.png
../_images/1.12_list.png
ITEMS IN THIS KIT
COMPONENT INTRODUCTION
PURCHASE LINK
GPIO Extension Board
Jumper Wires
Resistor
LED Bar Graph
Build the Circuit
../_images/1.12_image66.png
Load the Code and See What Happens
Load the code file (1.12_water_lamp.sb3) from your computer to Scratch 3.
By clicking on Arrow1, the LEDs on the LED bar are lit in sequence from the left to the right (one at a time) and then off. Click Arrow2 and the LEDs light up in the opposite order.
Tips on Sprites
Delete the default sprite and choose the Arrow1 sprite.
../_images/1.12_graph1.png
Here we will need 2 Arrow1 sprites, which can be done with the duplicate button.
../_images/1.12_scratch_duplicate.png
Click on the Arrow 2 sprite and change the direction of the arrow by selecting costume 2.
../_images/1.12_graph2.png
Now let’s make a variable.
../_images/1.12_graph3.png
Name it as num.
../_images/1.12_graph4.png
Follow the same method to create a list called led.
../_images/1.12_graph6.png
After adding, you should see the num variable and the led list on the stage area.
Click + to add 10 list items and enter the pin numbers in order (17,18,27,22,23,24,25,2,3,8).
../_images/1.12_graph7.png
Tips on Codes
../_images/1.12_graph10.png
This is an event block that is triggered when the current sprite is clicked.
../_images/1.12_graph8.png
The initial value of the num variable determines which LED is lit first.
../_images/1.12_graph9.png
Set the pin corresponding to num in the led list to low to light the LED, and then set the pin corresponding to num-1 to high to turn off the previous LED.
