Treasure Hunt
Arrange a maze in your room and place six different color cards in six corners. Then control PiCrawler to search for these color cards one by one!
You can download and print the PDF Color Cards for color detection.
Run the Code
cd /home/pi/picrawler/examples
sudo python3 treasure_hunt.py
View the Image
After the code runs, the terminal will display the following prompt:
No desktop !
* Environment: production
* Debug mode: off
Then you can enter http://<your IP>:9000/mjpg in the browser to view the video screen. such as: http://192.168.18.113:9000/mjpg
../_images/display.png
from time import sleep
from robot_hat import Music,TTS
from vilib import Vilib
import readchar
import random
import threading
crawler = Picrawler([10,11,12,4,5,6,1,2,3,7,8,9])
#crawler.set_offset([0,0,0,0,0,0,0,0,0,0,0,0])
music = Music()
tts = TTS()
manual = '''
Press keys on keyboard to control Picrawler!
        w: Forward
        a: Turn left
        s: Backward
        d: Turn right
        space: Say the target again
        esc: Quit
color = "red"
color_list=["red","orange","yellow","green","blue","purple"]
key_dict = {
        'w': 'forward',
        's': 'backward',
        'a': 'turn_left',
        'd': 'turn_right',
def renew_color_detect():
        global color
        color = random.choice(color_list)
        Vilib.color_detect(color)
        tts.say("Look for " + color)
key = None
lock = threading.Lock()
def key_scan_thread():
        global key
                key_temp = readchar.readkey()
                print('\r',end='')
                with lock:
                        key = key_temp.lower()
                        if key == readchar.key.SPACE:
                                key = 'space'
                        elif key == readchar.key.CTRL_C or key in readchar.key.ESCAPE_SEQUENCES:
                                key = 'quit'
                                break
                sleep(0.01)
def main():
        global key
        action = None
        Vilib.display(local=False,web=True)
        sleep(0.8)
        speed = 100
        print(manual)
        sleep(1)
        _key_t = threading.Thread(target=key_scan_thread)
        _key_t.setDaemon(True)
        _key_t.start()
        tts.say("game start")
        sleep(0.05)
                if Vilib.detect_obj_parameter['color_n']!=0 and Vilib.detect_obj_parameter['color_w']>100:
                        tts.say("will done")
                        sleep(0.05)
                with lock:
                        if key != None and key in ('wsad'):
                                action = key_dict[str(key)]
                                key =  None
                        elif key == 'space':
                                key =  None
                        elif key == 'quit':
                                _key_t.join()
                                Vilib.camera_close()
                                print("\n\rQuit")
                                break
                if action != None:
                        crawler.do_action(action,1,speed)
                        action = None
                sleep(0.05)
if __name__ == "__main__":
        main()
How it works?
In general, this project combines the knowledge points of Keyboard Control, Computer Vision and Sound Effect.
Its flow is shown in the figure below:
../_images/treasure_hunt-f.png
