Emotional Robot¶
This example shows several interesting custom actions of PiCrawler.
Run the Code
cd /home/pi/picrawler/examples
sudo python3 emotional_robot.py
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picrawler\examples. After modifying the code, you can run it directly to see the effect.
from time import sleep
crawler = Picrawler([10,11,12,4,5,6,1,2,3,7,8,9])
#crawler.set_offset([0,0,0,0,0,0,0,0,0,0,0,0])
def handwork(speed):
basic_step = []
basic_step = crawler.step_list.get("sit")
left_hand = crawler.mix_step(basic_step,0,[0,50,80])
right_hand = crawler.mix_step(basic_step,1,[0,50,80])
two_hand = crawler.mix_step(left_hand,1,[0,50,80])
crawler.do_step('sit',speed)
sleep(0.6)
crawler.do_step(left_hand,speed)
sleep(0.6)
crawler.do_step(two_hand,speed)
sleep(0.6)
crawler.do_step(right_hand,speed)
sleep(0.6)
sleep(0.6)
def twist(speed):
new_step=[[50, 50, -80], [50, 50, -80],[50, 50, -80], [50, 50, -80]]
for i in range(4):
for inc in range(30,60,5):
rise = [50,50,(-80+inc*0.5)]
drop = [50,50,(-80-inc)]
new_step[i]=rise
new_step[(i+2)%4] = drop
new_step[(i+1)%4] = rise
new_step[(i-1)%4] = drop
crawler.do_step(new_step,speed)
##"[[right front], [left front], [left rear], [left rear]]")
def pushup(speed):
up=[[80, 0, -100], [80, 0, -100],[0, 120, -60], [0, 120, -60]]
down=[[80, 0, -30], [80, 0, -30],[0, 120, -60], [0, 120, -60]]
crawler.do_step(up,speed)
sleep(0.6)
crawler.do_step(down,speed)
sleep(0.6)
def swimming(speed):
for i in range(100):
crawler.do_step([[100-i,i,0],[100-i,i,0],[0,120,-60+i/5],[0,100,-40-i/5]],speed)
# main
def main():
speed = 100
swimming(speed)
pushup(speed)
handwork(speed)
twist(speed)
sleep(0.05)
if __name__ == "__main__":
main()
