Micro SwitchΒΆ
img_micro_switch
The construction of a micro switch is really simple. The main parts of the switch are:
img_micro_switch2
  • 1.Plunger (Actuator)
  • 2.Cover
  • 3.Moving piece
  • 4.Support
  • 5.Case
  • 6.NO terminal: normally open
  • 7.NC terminal: normally closed
  • 8.Contact
  • 9.Moving arm
After a micro switch makes physical contact with an object, its contacts change position. The basic working principle is as follows.
When the plunger is in the released or rest position.
  • The normally closed circuit can carry current.
  • The normally open circuit is electrically insulated.
When the plunger is depressed or switched.
  • The normally closed circuit is open.
  • The normally open circuit is closed.
img_micro_switch1
Example
