2.1.6 Joystick(MCP3008)
In this project, We’re going to learn how joystick works. We manipulate the Joystick and display the results on the screen.
Principle
Joystick
The basic idea of a joystick is to translate the movement of a stick into electronic information that a computer can process.
In order to communicate a full range of motion to the computer, a joystick needs to measure the stick’s position on two axes – the X-axis (left to right) and the Y-axis (up and down). Just as in basic geometry, the X-Y coordinates pinpoint the stick’s position exactly.
To determine the location of the stick, the joystick control system simply monitors the position of each shaft. The conventional analog joystick design does this with two potentiometers, or variable resistors.
The joystick also has a digital input that is actuated when the joystick is pressed down.
Schematic Diagram
When the data of joystick is read, there are some differents between axis: data of X and Y axis is analog, which need to use MCP3008 to convert the analog value to digital value. Data of Z axis is digital, so you can directly use the GPIO to read, or you can also use ADC to read.
Experimental Procedures
Step 1: Build the circuit.
cd ~/davinci-kit-for-raspberry-pi/c/2.1.6-2/
Step 3: Compile the code.
gcc 2.1.6_Joystick.c -o joystick -lwiringPi
./joystick
After the code runs, turn the Joystick, then the corresponding values of x, y, Btn are displayed on screen.
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#define SPI_CHANNEL 0
#define SPI_SPEED 1000000 // 1 MHz
#define BtnPin 3 // WiringPi 3 = BCM GPIO22
// Read from MCP3008 channel (0–7)
int read_ADC(int channel) {
unsigned char buffer[3];
buffer[0] = 1; // Start bit
buffer[1] = (8 + channel) << 4; // Channel config
buffer[2] = 0;
int result = ((buffer[1] & 0x03) << 8) | buffer[2];
return result;
int main(void) {
if (wiringPiSetup() == -1) {
printf("WiringPi setup failed!\n");
printf("SPI setup failed!\n");
pinMode(BtnPin, INPUT);
pullUpDnControl(BtnPin, PUD_UP);
while (1) {
int x_val = read_ADC(0); // VRX on CH0
int y_val = read_ADC(1); // VRY on CH1
int btn_val = digitalRead(BtnPin); // SW button
printf("x = %d, y = %d, btn = %d\n", x_val, y_val, btn_val);
delay(100);
Code Explanation
This section initializes the libraries needed for GPIO and SPI communication.
#include <wiringPi.h> #include <wiringPiSPI.h> #include <stdio.h> #define SPI_CHANNEL 0 #define SPI_SPEED 1000000 // 1 MHz #define BtnPin 3 // WiringPi 3 = BCM GPIO22
Defines a function
read_ADC()to read analog data from MCP3008. It communicates over SPI to request data from a given channel (0–7), then parses the response to get a 10-bit ADC result.int read_ADC(int channel) { if (channel < 0 || channel > 7) return -1; unsigned char buffer[3]; buffer[0] = 1; buffer[1] = (8 + channel) << 4; buffer[2] = 0; wiringPiSPIDataRW(SPI_CHANNEL, buffer, 3); int result = ((buffer[1] & 0x03) << 8) | buffer[2]; return result; }
The main function initializes the WiringPi and SPI interfaces, configures the joystick’s button pin, and continuously reads joystick values and prints them to the console.
int main(void) { if (wiringPiSetup() == -1) { printf("WiringPi setup failed!\n"); return 1; } if (wiringPiSPISetup(SPI_CHANNEL, SPI_SPEED) == -1) { printf("SPI setup failed!\n"); return 1; } pinMode(BtnPin, INPUT); pullUpDnControl(BtnPin, PUD_UP); while (1) { int x_val = read_ADC(0); // VRX to CH0 int y_val = read_ADC(1); // VRY to CH1 int btn_val = digitalRead(BtnPin); // SW to GPIO22 printf("x = %d, y = %d, btn = %d\n", x_val, y_val, btn_val); delay(100); } return 0; }
In this program:
The joystick’s VRX is connected to CH0 of MCP3008.
The VRY is connected to CH1.
The button (SW) is connected to GPIO22 (WiringPi pin 3).
The
read_ADC()function is used to read analog values from VRX and VRY.The digital value of the joystick button is read using
digitalRead().All values are printed continuously every 100 milliseconds.
