2.1.4 Potentiometer(MCP3008)
The ADC function is used to convert analog signals into digital values. In this experiment, we use the MCP3008 ADC chip to perform this conversion. A potentiometer is used to generate a variable voltage, which changes the physical quantity. The MCP3008 then converts this analog voltage into a digital value that can be read and processed by the Raspberry Pi.
../_images/list2_2.1.4_potentiometer.png
Principle
MCP3008
MCP3008 is a 10-bit successive approximation analog-to-digital converter (ADC) with 8 input channels and an SPI (Serial Peripheral Interface) communication protocol. It is capable of interfacing with a microcontroller to convert analog input signals into digital data for further processing.
../_images/MCP3008.jpg
Sequence of Operation
A conversion on the MCP3008 begins by setting the CS (chip select) pin low, which activates communication with the device. The microcontroller then sends a 3-byte control stream via the SPI interface to specify the configuration and select the input channel.
The first byte sent contains the start bit and the single/differential selection bit. The next bits indicate which of the 8 channels (CH0–CH7) to read from. Data is shifted into the device on each rising edge of the SPI clock (SCLK), and the conversion result is returned simultaneously.
A short delay is included internally for the selected input channel to settle before conversion begins. The MCP3008 then performs a 10-bit analog-to-digital conversion using a sample-and-hold circuit and a successive approximation register (SAR) comparator.
The conversion result is transmitted back to the microcontroller through the MISO (Master In Slave Out) line. The most significant bit (MSB) of the 10-bit result is sent first, followed by the remaining bits. The microcontroller reads the result over the SPI bus during this time.
After the full 10-bit digital value is shifted out, the MCP3008 completes the cycle and waits for the next command.
../_images/MCP3008detail.png
Potentiometer
Potentiometer is also a resistance component with 3 terminals and its resistance value can be adjusted according to some regular variation. Potentiometer usually consists of resistor and movable brush. When the brush is moving along the resistor, there is a certain resistance or voltage output depending on the displacement.
../_images/image3101.png
The functions of the potentiometer in the circuit are as follows:
  1. Serving as a voltage divider
Potentiometer is a continuously adjustable resistor. When you adjust the shaft or sliding handle of the potentiometer, the movable contact will slide on the resistor. At this point, a voltage can be output depending on the voltage applied onto the potentiometer and the angle the movable arm has rotated to or the distance it moves.
Schematic Diagram
T-Board Name
physical
WiringPi
SPICE0
pin24
10
8
SPIMOSI
pin19
12
10
SPIMISO
pin21
13
9
SPISCLK
pin23
14
11
GPIO22
pin15
../_images/schematic_2.1.7_potentiometer_mcp3008.png
Experimental Procedures
Step 1: Build the circuit.
../_images/july24_2.1.7_potentiometer_mcp3008.png
Please place the chip by referring to the corresponding position depicted in the picture. Note that the grooves on the chip should be on the left when it is placed.
Step 2: Open the code file.
cd ~/davinci-kit-for-raspberry-pi/c/2.1.4-2/
Step 3: Compile the code.
gcc 2.1.4_Potentiometer.c -lwiringPi
Step 4: Run.
After the code runs, rotate the knob on the potentiometer, the intensity of LED will change accordingly.
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#include <softPwm.h>
#define SPI_CHANNEL 0  // CE0
#define SPI_SPEED   1000000  // 1MHz
#define LedPin      3
int readADC(int channel) {
    unsigned char buffer[3];
    buffer[0] = 1;                             // Start bit
    buffer[1] = (8 + channel) << 4;            // Single-ended mode, channel
    buffer[2] = 0;
    int value = ((buffer[1] & 3) << 8) | buffer[2];
    return value;
int main(void) {
    if (wiringPiSetup() == -1) {
        printf("WiringPi init failed!\n");
        printf("SPI setup failed!\n");
    softPwmCreate(LedPin, 0, 100);
    while (1) {
        int analogVal = readADC(0);  // CH0
        printf("ADC Value: %d\n", analogVal);
        int pwmVal = analogVal * 100 / 1023;  // Normalize to 0–100
        softPwmWrite(LedPin, pwmVal);
        delay(100);
Code Explanation
#define LedPin      3
Define the SPI channel as CE0 (chip enable 0), set the SPI speed to 1MHz, and assign GPIO3 to the LED pin.
    buffer[2] = 0;
    return value;
This function is used to read analog data from MCP3008.
  • First, it checks if the channel number is within the valid range (0 to 7).
  • It initializes a 3-byte array, where:
    • buffer[0] = 1: Start bit for MCP3008 communication.
    • buffer[1] = (8 + channel) << 4: Constructs the configuration byte for single-ended mode and selects the desired channel.
    • buffer[2] = 0: Placeholder byte to receive the result.
  • wiringPiSPIDataRW sends and receives data through the SPI channel.
  • The return value is extracted from the last two bytes using bitwise operations to obtain a 10-bit ADC result.
int main(void) {
    while (1) {
        delay(100);
In the main function:
  • wiringPiSetup() initializes the WiringPi library.
  • wiringPiSPISetup() initializes SPI communication on channel 0 at 1MHz.
  • softPwmCreate() sets up software PWM on GPIO3 with an initial duty cycle of 0 and a range of 0–100.
The program enters an infinite loop where:
  • It reads the ADC value from channel 0 (connected to a potentiometer).
  • Prints the ADC value to the terminal.
  • Converts the 10-bit ADC value to a PWM duty cycle between 0 and 100.
  • Writes the PWM value to the LED, so the brightness reflects the potentiometer’s position.
delay(100) pauses for 100 milliseconds before the next read/write cycle.
