.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
.. _2.1.6_c_pi5_mcp3008:
2.1.6 Joystick(MCP3008)
.. note::
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
In this project, We're going to learn how joystick works. We manipulate
the Joystick and display the results on the screen.
.. image:: ../img/image317-copy.png
Principle
**Joystick**
The basic idea of a joystick is to translate the movement of a stick
into electronic information that a computer can process.
In order to communicate a full range of motion to the computer, a
joystick needs to measure the stick's position on two axes -- the X-axis
(left to right) and the Y-axis (up and down). Just as in basic geometry,
the X-Y coordinates pinpoint the stick's position exactly.
To determine the location of the stick, the joystick control system
simply monitors the position of each shaft. The conventional analog
joystick design does this with two potentiometers, or variable
resistors.
The joystick also has a digital input that is actuated when the joystick
is pressed down.
.. image:: img/image318.png
Schematic Diagram
When the data of joystick is read, there are some differents between
axis: data of X and Y axis is analog, which need to use MCP3008 to
convert the analog value to digital value. Data of Z axis is digital, so
you can directly use the GPIO to read, or you can also use ADC to read.
.. .. image:: ../img/image319.png
* - T-Board Name
- physical
- WiringPi
- BCM
* - SPICE0
- pin24
- 10
- 8
* - SPIMOSI
- pin19
- 12
- 10
* - SPIMISO
- pin21
- 13
- 9
* - SPISCLK
- pin23
- 14
- 11
* - GPIO22
- pin15
- 3
- 22
.. image:: ../img/schematic_2.1.9_joystick_mcp3008.png
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: ../img/july24_2.1.9_joystick_mcp3008.png
**Step 2:** Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/2.1.6-2/
**Step 3:** Compile the code.
.. raw:: html
.. code-block::
gcc 2.1.6_Joystick.c -o joystick -lwiringPi
**Step 4:** Run the executable file.
.. raw:: html
.. code-block::
./joystick
After the code runs, turn the Joystick, then the corresponding values of
x, y, Btn are displayed on screen.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
**Code**
.. code-block:: c
#include
#include
#include
#define SPI_CHANNEL 0
#define SPI_SPEED 1000000 // 1 MHz
#define BtnPin 3 // WiringPi 3 = BCM GPIO22
// Read from MCP3008 channel (0–7)
int read_ADC(int channel) {
unsigned char buffer[3];
buffer[0] = 1; // Start bit
buffer[1] = (8 + channel) << 4; // Channel config
buffer[2] = 0;
int result = ((buffer[1] & 0x03) << 8) | buffer[2];
return result;
int main(void) {
if (wiringPiSetup() == -1) {
printf("WiringPi setup failed!\n");
printf("SPI setup failed!\n");
pinMode(BtnPin, INPUT);
pullUpDnControl(BtnPin, PUD_UP);
while (1) {
int x_val = read_ADC(0); // VRX on CH0
int y_val = read_ADC(1); // VRY on CH1
int btn_val = digitalRead(BtnPin); // SW button
printf("x = %d, y = %d, btn = %d\n", x_val, y_val, btn_val);
delay(100);
**Code Explanation**
#. This section initializes the libraries needed for GPIO and SPI communication.
.. code-block:: c
#include
#include
#include
#. Defines a function ``read_ADC()`` to read analog data from MCP3008. It communicates over SPI to request data from a given channel (0–7), then parses the response to get a 10-bit ADC result.
.. code-block:: c
buffer[0] = 1;
buffer[2] = 0;
return result;
#. The main function initializes the WiringPi and SPI interfaces, configures the joystick's button pin, and continuously reads joystick values and prints them to the console.
.. code-block:: c
int main(void) {
while (1) {
int x_val = read_ADC(0); // VRX to CH0
int y_val = read_ADC(1); // VRY to CH1
int btn_val = digitalRead(BtnPin); // SW to GPIO22
delay(100);
#. In this program:
- The joystick's VRX is connected to CH0 of MCP3008.
- The VRY is connected to CH1.
- The button (SW) is connected to GPIO22 (WiringPi pin 3).
- The ``read_ADC()`` function is used to read analog values from VRX and VRY.
- The digital value of the joystick button is read using ``digitalRead()``.
- All values are printed continuously every 100 milliseconds.
.. Phenomenon Picture
.. .. image:: ../img/image194.jpeg
