Bluetooth Environmental Monitor
This project uses an Android app created with MIT App Inventor to receive and display environmental data from an Arduino board. The Arduino board fetches data from a DHT11 sensor to measure temperature and humidity. Once the data is collected, it’s transmitted over Bluetooth using the JDY-31 module.APP will display the data on the screen once it receives it.
The Android application will be constructed utilizing a complimentary web-based platform known as MIT App Inventor. The project presents an excellent opportunity to gain familiarity with the interfacing of an Arduino with a smartphone.
1. Build the Circuit
The kit may contain different versions of the DHT11 module. Please confirm the wiring method according to the module you have.
module |
diagram |
2. Create the Android App
The Android application will be developed using a free web application known as MIT App Inventor. MIT App Inventor serves as an excellent starting point for Android development, owing to its intuitive drag-and-drop features allowing for the creation of simplistic applications.
Now, let’s begin.
Go to Get Started with MIT App Inventor, and click “online tool” to login. You will require a Google account to register with MIT App Inventor.
After logging in, navigate to Projects -> Import project (.aia) from my computer. Subsequently, upload the
Bluetooth_controlled_lock.aiafile located in the pathultimate-sensor-kit\iot_project\bluetooth\05-Bluetooth_environmental_monitor.You can also directly download here:
Bluetooth_Environmental_Monitor.aia
Upon uploading the
.aiafile, you will see the application on the MIT App Inventor software. This is a pre-configured template. You can modify this template after you have familiarized yourself with MIT App Inventor through the following steps.In MIT App Inventor, you have 2 primary sections: the Designer and the Blocks. You can switch between these two sections in the upper right corner of the page.
The Designer allows you to add buttons, text, screens, and modify the overall aesthetic of your application.
Next, there’s the Blocks section. This section lets you craft custom functionalities for your app, allowing you to program each component on the app’s GUI to achieve desired features.
To install the application on a smartphone, navigate to the Build tab.
You can generate a
.apkfile. After selecting this option, a page will appear allowing you to choose between downloading a.apkfile or scanning a QR code for installation. Follow the installation guide to complete the application installation.You also download our pre-compiled APK here:
Bluetooth_Environmental_Monitor.apkIf you wish to upload this app to Google Play or another app marketplace, you can generate a
.aabfile.
3. Upload the Code
Open the
05-Bluetooth_environmental_monitor.inofile under the path ofultimate-sensor-kit\iot_project\bluetooth\05-Bluetooth_environmental_monitor, or copy this code into Arduino IDE.Note
To install the library, use the Arduino Library Manager and search for “DHT sensor library” and install it.
After selecting the correct board and port, click the Upload button.
Open the Serial monitor(set baudrate to 9600) to view debug messages.
4. App and Bluetooth module Connection
Ensure that the application created earlier is installed on your smartphone.
Initially, turn on Bluetooth on your smartphone.
Navigate to the Bluetooth settings on your smartphone and look for names like JDY-31-SPP.
After clicking it, agree to the Pair request in the pop-up window. If prompted for a pairing code, please enter “1234”.
Now open the newly installed Environmental Monitor APP.
In the APP, click on Connect button to establish a connection between the APP and Bluetooth module.
This page displays a list of all paired Bluetooth devices. Choose the
xx.xx.xx.xx.xx.xx JDY-31-SPPoption from the list. The name of each device is listed next to its MAC address.
If you don’t see any devices on the page shown above, it could be because this app is not authorized to scan for nearby devices. In such a case, you will need to adjust the settings manually.
To access the APP Info page, long-press the app icon and select it. Alternatively, if you have another method to reach this page, use that instead.
Navigate to the Permissions page.
To enable the APP to scan for nearby devices, go to Nearby devices and select Always.
Now, restart the APP and repeat steps 5 and 6 to successfully connect to Bluetooth.
After a successful connection, you will be redirected to the main page where it will display temperature and humidity.
5. Code explanation
Setting up Bluetooth communication and DHT11 sensor.
#include <SoftwareSerial.h> const int bluetoothTx = 3; const int bluetoothRx = 4; SoftwareSerial bleSerial(bluetoothTx, bluetoothRx); #include <DHT.h> #define DHTPIN 2 #define DHTTYPE DHT11 DHT dht(DHTPIN, DHTTYPE);
The code includes necessary libraries and defines pins for the Bluetooth module and DHT11 sensor. It also declares objects for Bluetooth communication and DHT11.
Initialization in setup function.
void setup() { Serial.begin(9600); bleSerial.begin(9600); dht.begin(); }
This segment initializes serial communication for debugging, Bluetooth module, and the DHT sensor.
Reading data and sending via Bluetooth.
void loop() { delay(2000); float humidity = dht.readHumidity(); float temperature = dht.readTemperature(); // Check if any reads failed and exit early (to try again). if (isnan(humidity) || isnan(temperature)) { Serial.println(F("Failed to read from DHT sensor!")); return; } // For debug // Print the humidity and temperature to the serial monitor Serial.print(F("Humidity: ")); Serial.print(humidity); Serial.print(F("% Temperature: ")); Serial.print(temperature); Serial.println(F("°C ")); sensorData = String(temperature) + "," + String(humidity); // Concatenate temperature and humidity values Serial.print("Data to send: "); Serial.println(sensorData); bleSerial.println(sensorData); // Send temperature and humidity values to the Bluetooth module }
This segment reads temperature and humidity from the DHT11 sensor every 2 seconds. If the reading fails, it prints an error message. Otherwise, it prints the readings to the Serial Monitor and sends them via the Bluetooth module in a comma-separated format. When the app receives data in the format of “temperature,humidity”, it will parse the information and present it on the user interface.
