Component BasicsΒΆ
After opening the package, please check whether the quantity of components is compliance with product description and whether all components are in good condition.
The following is an introduction to each component, including its working principle and corresponding project. Each component has a simple code example to help you get started quickly.
Control Board
Sensor
- Ultrasonic Sensor Module (HC-SR04)
- Gas/Smoke Sensor Module (MQ2)
- Flame Sensor Module
- Vibration Sensor Module (SW-420)
- Accelerometer & Gyroscope Module (MPU6050)
- Button Module
- Photoresistor Module
- Potentiometer Module
- IR Obstacle Avoidance Sensor Module
- Capacitive Soil Moisture Module
- Raindrop Detection Module
- Temperature and Humidity Sensor Module (DHT11)
- PIR Motion Module (HC-SR501)
- Temperature, Humidity & Pressure Sensor (BMP280)
- Pulse Oximeter and Heart Rate Sensor (MAX30102)
- Real Time Clock Module (DS1302)
- Touch Sensor Module
- Infrared Speed Sensor Module
- Joystick Module
- Time of Flight Micro-LIDAR Distance Sensor (VL53L0X)
Display
Actuator
Wireless & IoT
