11. 记录新动作
我们使用键盘依次控制 PiCrawler 做出几个姿态,并将这些姿态记录下来,之后可以进行回放。
运行代码
cd ~/picrawler/examples
sudo python3 11_record_new_step.py
代码运行后,请根据终端中弹出的提示进行操作。
  • 按下 1234 分别选择不同的脚, 1 : 右前脚, 2: 左前脚, 3: 左后脚, 4 : 右后脚
  • 按下 wasdrf 来逐步控制 PiCrawler 的坐标值
  • 按下 space 打印所有坐标值
  • 按下 p 回放已记录的动作
  • 按下 esc 退出程序
代码
from time import sleep
import sys
import tty
import termios
import copy
crawler = Picrawler()
speed = 80
def readchar():
    fd = sys.stdin.fileno()
    old_settings = termios.tcgetattr(fd)
        tty.setraw(sys.stdin.fileno())
        ch = sys.stdin.read(1)
    finally:
        termios.tcsetattr(fd, termios.TCSADRAIN, old_settings)
    return ch
manual = '''
Press keys on keyboard to control!
    w: Y++
    a: X--
    s: Y--
    d: X++
    r: Z++
    f: Z--
    1: Select right front leg
    2: Select left front leg
    3: Select left rear leg
    4: Select right rear leg
    Space: Print all leg coodinate & Save this step
    p: Play all saved step
    esc: Quit
new_step=[]
def save_new_step():
    new_step.append(copy.deepcopy(crawler.current_step_all_leg_value()))
    print(new_step)
def play_all_new_step():
    for step in new_step:
        crawler.do_step(step,speed)
        sleep(0.6)
def main():
    speed = 80
    print(manual)
    crawler.do_step('sit',speed)
    leg = 0
    coodinate=crawler.current_step_leg_value(leg)
        key = readchar()
        key = key.lower()
        # print(key)
        if 'w' == key:
            coodinate[1]=coodinate[1]+2
        elif 's' == key:
            coodinate[1]=coodinate[1]-2
        elif 'a' == key:
            coodinate[0]=coodinate[0]-2
        elif 'd' == key:
            coodinate[0]=coodinate[0]+2
        elif 'r' == key:
            coodinate[2]=coodinate[2]+2
        elif 'f' == key:
            coodinate[2]=coodinate[2]-2
        elif '1' == key:
            leg=0
        elif '2' == key:
            leg=1
        elif '3' == key:
            leg=2
        elif '4' == key:
            leg=3
        elif chr(32) == key:
            print("[[right front],[left front],[left rear],[right rear]]")
            print("saved new step")
            print(crawler.current_step_all_leg_value())
            save_new_step()
        elif 'p' == key:
            play_all_new_step()
        elif chr(27) == key:# 27 for ESC
            break
        sleep(0.05)
        crawler.do_single_leg(leg,coodinate,speed)
    print("\n q Quit")
if __name__ == "__main__":
    main()
它是如何工作的?
该项目基于 10. 调整姿态 开发,并新增了动作记录与回放功能。
动作记录功能由以下代码实现:
new_step=[]
    print(new_step)
备注
这里必须使用 Deep Copy ,否则在 appendnew_step 不会得到一个新的数组对象。
动作回放功能由以下代码实现:
        sleep(0.6)
