3.6 Controlling a Water Pump
In this lesson, we’ll learn how to control a small water pump using the Raspberry Pi Pico 2 W and an TA6586 motor driver. A small centrifugal pump can be used for projects like automatic plant watering systems or creating miniature water features. Controlling the pump is similar to controlling a DC motor, as it uses the same principles.
ITEMS IN THIS KIT
PURCHASE LINK
Pico 2 W Starter Kit
450+
Pico 2 W Kit
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Getting to Know Pico 2 W
Micro USB Cable
Jumper Wires
Several
TA6586 - Motor Driver Chip
Li-po Charger Module
Power Pack
DC Water Pump
Schematic
sch_pump
  • Since pump require a high current, we use a Li-po Charger module to power the motor here for safety reasons.
  • Make sure your Li-po Charger Module is connected as shown in the diagram. Otherwise, a short circuit will likely damage your Power Pack and circuitry.
wiring_pump
  • You can open the file 3.6_pumping.ino under the path of pico-2w-kit-main/arduino/3.6_pumping.
  • Don’t forget to select the board(Raspberry Pi Pico) and the correct port before clicking the Upload button.
const int motor1A = 14; // Motor control pin 1
const int motor2A = 15; // Motor control pin 2
  // Set motor control pins as OUTPUT
  pinMode(motor1A, OUTPUT); // Configure motor1A as an output pin
  pinMode(motor2A, OUTPUT); // Configure motor2A as an output pin
  // Rotate the motor in a clockwise direction
  digitalWrite(motor1A, HIGH); // Set motor1A to HIGH (activates one side of the motor)
  digitalWrite(motor2A, LOW);  // Set motor2A to LOW (deactivates the opposite side of the motor)
After the code is run, the pump starts working and you will see water flowing out of the tube at the same time. * This cycle repeats indefinitely. * If water doesn’t flow initially, make sure the pump is submerged, and there are no air bubbles in the tubing.
Safety Precautions
  • Water and Electricity:
    • Be extremely careful to keep water away from the Pico and other electronic components.
    • Ensure all connections are secure and insulated if necessary.
  • Power Supply:
    • Use a power supply that matches the pump’s voltage requirements (typically 3V-6V).
    • Do not power the pump directly from the Pico’s 3.3V pin.
  • Current Draw:
    • Pumps can draw significant current.
    • Ensure your power source can handle the pump’s current requirements.
  • Resetting the Pico:
    If you encounter issues uploading code after running the pump, you can manually reset the Pico by connecting the RUN pin to GND momentarily.
    wiring_run_reset
Further Exploration
  • Automated Plant Watering:
    Incorporate soil moisture sensors to automate the watering process based on soil dryness.
  • PWM Speed Control:
    Use Pulse Width Modulation (PWM) to control the pump’s speed by varying the voltage.
  • Timing and Scheduling:
    Implement more complex timing using real-time clocks or schedulers.
Conclusion
In this lesson, you’ve learned how to control a small water pump using the Raspberry Pi Pico and the TA6586 motor driver. This technique can be used in various projects like automated plant watering systems, fountains, or hydroponic setups.
