3.3 Controlling an RGB LED Strip
In this lesson, we’ll learn how to control an RGB LED strip (specifically the WS2812 type) using the Raspberry Pi Pico 2 W and MicroPython.
The WS2812 is a smart LED that integrates a control circuit and an RGB chip into a 5050-sized LED package. Each LED has its own built-in controller, which allows us to control each LED individually using a single data line. This means we can change the color and brightness of each LED on the strip independently.
PURCHASE LINK |
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Micro USB Cable |
Several |
Schematic
Be cautious with the current draw. While the Pico’s VBUS pin can supply power for a small number of LEDs (like 8), using more LEDs may require an external power supply to prevent overloading the Pico.
Writing the Code
You can open the file
3.3_rgb_led_strip.inounder the path ofpico-2w-kit-main/arduino/3.3_rgb_led_strip.Or copy this code into Arduino IDE.
Then select the Raspberry Pi Pico board and the correct port before clicking the Upload button.
The
Adafruit_NeoPixellibrary is used here, you can install it from the Library Manager.
#include <Adafruit_NeoPixel.h>
#define PIXEL_PIN 0 // Digital IO pin connected to the NeoPixels
#define PIXEL_COUNT 8 // Number of NeoPixels
// Declare our NeoPixel strip object
Adafruit_NeoPixel strip(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
strip.begin(); // Initialize the NeoPixel library
strip.show(); // Turn OFF all pixels ASAP
// Set the color of each pixel
strip.setPixelColor(0, strip.Color(255, 0, 0)); // Red
strip.setPixelColor(1, strip.Color(0, 255, 0)); // Green
strip.setPixelColor(2, strip.Color(0, 0, 255)); // Blue
strip.setPixelColor(3, strip.Color(255, 255, 0)); // Yellow
strip.setPixelColor(4, strip.Color(0, 255, 255)); // Cyan
strip.setPixelColor(5, strip.Color(255, 0, 255)); // Magenta
strip.setPixelColor(6, strip.Color(255, 255, 255)); // White
strip.setPixelColor(7, strip.Color(0, 0, 0)); // Off
strip.show(); // Update the strip with new contents
delay(1000); // Wait for a second
// Turn off all pixels
strip.clear();
strip.show();
After uploading the code, you should see the LEDs light up with different colors, stay on for a second, then turn off for a second.
Understanding the Code
Include the Library:
Define Constants:
PIXEL_PIN: The GPIO pin connected to the data input of the LED strip (GP0).PIXEL_COUNT: The number of LEDs on the strip.
Initialize the Strip:
NEO_GRB + NEO_KHZ800: Specifies the color order and communication speed.Adafruit_NeoPixel strip(PIXEL_COUNT, PIXEL_PIN, NEO_GRB + NEO_KHZ800);
In
setup()function:strip.begin(): Initializes the NeoPixel library.strip.show(): Ensures all pixels are off.
In
loop()function:strip.setPixelColor(index, color): Sets the color of a specific pixel.strip.Color(r, g, b): Creates a 24-bit color value from red, green, and blue components (0-255).strip.show(): Sends the updated color data to the strip.strip.clear(): Clears the pixel data in memory (turns off the pixels on the nextshow()).
Advanced Example: Color Wipe Animation
Let’s create a simple animation where each LED lights up in sequence.
colorWipe(): Lights up each pixel in sequence with the specified color.Calls
colorWipe()with different colors to create an animation.
#define PIXEL_PIN 0
strip.begin();
strip.show(); // Initialize all pixels to 'off'
colorWipe(strip.Color(255, 0, 0), 50); // Red
colorWipe(strip.Color(0, 255, 0), 50); // Green
colorWipe(strip.Color(0, 0, 255), 50); // Blue
void colorWipe(uint32_t color, int wait) {
for(int i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, color);
strip.show();
delay(wait);
After uploading the code, you should see the LEDs light up one by one in red, then green, then blue.
Advanced Example: Rainbow Cycle Animation
rainbowCycle()Function: Cycles through the colors of the rainbow across all pixels.The nested loops create a smooth transition of colors.
Wheel()Function: Generates rainbow colors across 0-255 positions.
#define PIXEL_PIN 0
strip.begin();
rainbowCycle(20); // Rainbow cycle with 20ms delay per step
void rainbowCycle(int wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on the wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colors are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
After uploading the code, the LED strip should display a rainbow of colors cycling smoothly.
Further Exploration
Create Custom Animations:
Experiment with different colors and animations.
Combine multiple animation functions.
Respond to Sensors:
Use input from sensors to change the LED colors or patterns.
Build a Visualizer:
Create a music visualizer that changes the LEDs based on sound input.
Power Considerations
Current Draw:
Each LED can draw up to 60mA at full brightness.
For 8 LEDs, that’s up to 480mA.
Ensure your power source can supply the required current.
External Power Supply:
For larger strips or higher brightness, use an external 5V power supply.
Connect the ground of the external power supply to the Pico’s ground.
Conclusion
In this lesson, you’ve learned how to control a WS2812 RGB LED strip using the Raspberry Pi Pico and the Adafruit NeoPixel library. By manipulating individual pixels, you can create stunning visual effects for your projects.
