3.7 Swinging Servo
In this lesson, we’ll learn how to control a servo motor using the Raspberry Pi Pico 2 W. A servo motor is a device that can rotate to a specific angle between 0° and 180°. It’s widely used in remote control toys, robots, and other applications that require precise position control.
Let’s get started and make the servo swing back and forth!
PURCHASE LINK |
Pico 2 W Starter Kit |
450+ |
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Micro USB Cable |
Several |
Schematic
Orange wire is signal and connected to GP15.
Red wire is VCC and connected to VBUS(5V).
Brown wire is GND and connected to GND.
Servos can draw significant current, especially under load. Since we’re using a small servo and not putting it under heavy load, powering it from the Pico’s VBUS pin is acceptable for this simple experiment. For larger servos or multiple servos, use an external power supply.
Setting Up the Servo Arm
Attach the servo arm (also called a horn) to the servo’s output shaft.
Secure it with the small screw provided with the servo if necessary.
Writing the Code
You can open the file
3.7_swinging_servo.inounder the path ofpico-2w-kit-main/arduino/3.7_swinging_servo.Or copy this code into Arduino IDE.
Don’t forget to select the board(Raspberry Pi Pico) and the correct port before clicking the Upload button.
#include <Servo.h>
Servo myServo; // Create a servo object
myServo.attach(15); // Attach the servo to GPIO pin 15
// Move the servo from 0 to 180 degrees
for (int angle = 0; angle <= 180; angle += 1) {
myServo.write(angle);
delay(15); // Wait 15 milliseconds for the servo to reach the position
// Move the servo from 180 to 0 degrees
for (int angle = 180; angle >= 0; angle -= 1) {
delay(15);
After uploading the code, the servo arm should start swinging smoothly from 0° to 180° and back. If the servo doesn’t move or behaves erratically:
Check your wiring connections.
Ensure the servo is properly powered.
Make sure the servo is not mechanically blocked.
Understanding the Code
Including the
ServoLibrary:Includes the
Servolibrary, which provides functions to control the servo motor.#include <Servo.h>
Creating a
ServoObject:Creates a
Servoobject namedmyServoto control the servo.Servo myServo;
Attaching the Servo to a Pin:
Attaches the servo to GPIO pin 15 on the Pico.
myServo.attach(15);
Moving the Servo:
Moves the servo from 0° to 180° in 1-degree increments. The delay(15) provides a small delay to allow the servo to reach each position smoothly.
for (int angle = 0; angle <= 180; angle += 1) { myServo.write(angle); delay(15); }
Reversing the Movement: Moves the servo back from 180° to 0°, creating a back-and-forth swinging motion.
for (int angle = 180; angle >= 0; angle -= 1) { myServo.write(angle); delay(15); }
Further Exploration
Adjusting Speed:
Change the
delay()value in the loops to make the servo move faster or slower.Controlling Position Directly:
Use
myServo.write(angle);with a specific angle to set the servo to a fixed position.Interactive Control:
Connect a potentiometer to control the servo angle interactively.
Conclusion
In this lesson, you’ve learned how to control a servo motor using the Raspberry Pi Pico and the Servo library. By adjusting the code, you can set the servo to any angle between 0° and 180°, allowing for precise control in your projects.
