Video Car¶
This program will provide a First Person View from the PiCar-X! Use the keyboards WSAD keys to control the direction of movement, and the O and P to adjust the speed.
Run the Code
This project requires access to the Raspberry Pi desktop to view the footage taken by the camera module.
You can connect a screen to the PiCar-X or refer to the tutorial Remote Desktop to access it with VNC or XRDP.
Once inside the Raspberry Pi desktop, open Terminal and type the following command to run it, or just open and run it with a Python editor.
cd /home/pi/picar-x/example
sudo python3 video_car.py
Once the code is running, you can see what PiCar-X is shooting and control it by pressing the following keys.
O: speed up
P: speed down
W: forward
S: backward
A: turn left
D:turn right
F: stop
T: take photo
ESC / Ctrl+C: quit
code
# #!/usr/bin/env python3
print('Please run under desktop environment (eg: vnc) to display the image window')
from utils import reset_mcu
reset_mcu()
from picarx import Picarx
from vilib import Vilib
from time import sleep, time, strftime, localtime
import readchar
manual = '''
Press key to call the function(non-case sensitive):
O: speed up
P: speed down
W: forward
S: backward
A: turn left
D:turn right
F: stop
T: take photo
ESC / Ctrl+C: quit
px = Picarx()
def take_photo():
_time = strftime('%Y-%m-%d-%H-%M-%S',localtime(time()))
name = 'photo_%s'%_time
path = "/home/pi/Pictures/picar-x/"
Vilib.take_photo(name, path)
print('\nphoto save as %s%s.jpg'%(path,name))
def move(operate:str, speed):
if operate == 'stop':
px.stop()
if operate == 'forward':
px.set_dir_servo_angle(0)
px.forward(speed)
elif operate == 'backward':
px.backward(speed)
elif operate == 'turn left':
px.set_dir_servo_angle(-30)
px.forward(speed)
elif operate == 'turn right':
px.set_dir_servo_angle(30)
px.forward(speed)
def main():
speed = 0
status = 'stop'
sleep(2) # wait for startup
print(manual)
print("\rstatus: %s , speed: %s "%(status, speed), end='', flush=True)
# readkey
key = readchar.readkey().lower()
# operation
if key in ('wsadfop'):
# throttle
if key == 'o':
if speed <=90:
speed += 10
elif key == 'p':
if speed >=10:
speed -= 10
if speed == 0:
status = 'stop'
# direction
elif key in ('wsad'):
if speed == 0:
speed = 10
if key == 'w':
# Speed limit when reversing,avoid instantaneous current too large
if status != 'forward' and speed > 60:
speed = 60
status = 'forward'
elif key == 'a':
status = 'turn left'
elif key == 's':
if status != 'backward' and speed > 60: # Speed limit when reversing
speed = 60
status = 'backward'
elif key == 'd':
status = 'turn right'
# stop
elif key == 'f':
status = 'stop'
# move
move(status, speed)
# take photo
elif key == 't':
take_photo()
# quit
elif key == readchar.key.CTRL_C or key in readchar.key.ESCAPE_SEQUENCES:
print('\nquit ...')
px.stop()
Vilib.camera_close()
break
sleep(0.1)
if __name__ == "__main__":
main()
except Exception as e:
print("error:%s"%e)
finally:
px.stop()
