Let PiCar-X Move
This is the first project, let’s test the basic movement of Picar-X.
Run the Code
cd /home/pi/picar-x/example
sudo python3 move.py
After running the code, PiCar-X will move forward, turn in an S-shape, stop and shake its head.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picar-x/example. After modifying the code, you can run it directly to see the effect.
from picarx import Picarx
if __name__ == "__main__":
        px = Picarx()
        px.forward(30)
        time.sleep(0.5)
        for angle in range(0,35):
            px.set_dir_servo_angle(angle)
            time.sleep(0.01)
        for angle in range(35,-35,-1):
            time.sleep(0.01)
        for angle in range(-35,0):
            time.sleep(0.01)
        px.forward(0)
        time.sleep(1)
            px.set_camera_servo1_angle(angle)
            time.sleep(0.01)
            time.sleep(0.01)
            time.sleep(0.01)
            px.set_camera_servo2_angle(angle)
            time.sleep(0.01)
            time.sleep(0.01)
            time.sleep(0.01)
    finally:
        px.forward(0)
How it works?
The basic functionality of Parker is in the picarx module, Can be used to control steering gear and wheels, and will make the PiCar-X move forward, turn in an S-shape, or shake its head.
Now, the libraries to support the basic functionality of PiCar-X are imported. These lines will appear in all the examples that involve PiCar-X movement.
The following function with the for loop is then used to make PiCar-X move forward, change directions, and move the camera’s pan/tilt.
px.forward(speed)
  • forward(): Orders the PiCar-X go forward at a given speed.
  • set_dir_servo_angle: Turns the Steering servo to a specific angle.
  • set_camera_servo1_angle: Turns the Pan servo to a specific angle.
  • set_camera_servo2_angle: Turns the Tilt servo to a specific angle.
../_images/pan_tilt_servo.png
