Text to Speech¶
Before using the Text-to-Speech (TTS) functions, first activate the speaker so that it will be enabled and can make sounds.
Run i2samp.sh
in the picar-x folder, and this script will install everything needed to use i2s amplifier.
cd /home/pi/picar-x
sudo bash i2samp.sh
There will be several prompts asking to confirm the request. Respond to all prompts with a Y. After the changes have been made to the Raspberry Pi system, the computer will need to reboot for these changes to take effect.
After rebooting, run the i2samp.sh
script again to test the amplifier. If a sound successfully plays from the speaker, the configuration is complete.
Run the Code
cd /home/pi/picar-x/example
sudo python3 tts_example.py
After running the code, PiCar-X will say “Hello”, “Hi”, “Good bye”, “Nice to meet you”.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picar-x/example
. After modifying the code, you can run it directly to see the effect.
from robot_hat import TTS
if __name__ == "__main__":
words = ["Hello", "Hi", "Good bye", "Nice to meet you"]
tts_robot = TTS()
for i in words:
print(i)
tts_robot.say(i)
How it works?
The eSpeak software is used to implement the functions of TTS.
Import the TTS module in robot_hat, which encapsulates functions that convert text to speech.
Create a string list words
, then create an instantiated object of the TTS() class tts_robot
, and finally use the tts_robot.say()
function to speak the words in the list in speech.
tts_robot = TTS()
for i in words:
print(i)
tts_robot.say(i)
