Computer Vision¶
This next project will officially enter the field of computer vision!
To perform the next four experiments, make sure to have completed the Remote Desktop. A remote connection via SSH will not display the camera images.
Run the Code
This project requires access to the Raspberry Pi desktop to view the footage taken by the camera module.
You can connect a screen to the PiCar-X or refer to the tutorial Remote Desktop to access it with VNC or XRDP.
Once inside the Raspberry Pi desktop, open Terminal and type the following command to run it, or just open and run it with a Python editor.
cd /home/pi/picar-x/example
sudo python3 computer_vision.py
After the code is run, you will see a window open on your desktop showing the shot.
import cv2
from picamera.array import PiRGBArray
from picamera import PiCamera
with PiCamera() as camera:
camera.resolution = (640, 480)
camera.framerate = 24
rawCapture = PiRGBArray(camera, size=camera.resolution)
time.sleep(2)
for frame in camera.capture_continuous(rawCapture, format="bgr",use_video_port=True): # use_video_port=True
img = frame.array
cv2.imshow("video", img) # OpenCV image show
rawCapture.truncate(0) # Release cache
k = cv2.waitKey(1) & 0xFF
if k == 27:
break
print('quit ...')
cv2.destroyAllWindows()
camera.close()
How it works?
Photos are obtained with PiCamera
. This package provides a pure Python interface to the Raspberry Pi camera.
Capturing an image to a file only requires specifying the name of the file to the output of whatever capture()
method was required.
from time import sleep
camera.start_preview()
# Camera warm-up time
sleep(2)
camera.capture('foo.jpg')
This project uses the capturing timelapse sequences method. This method enables OpenCV to acquire sequential frames.
With this method, the camera captures images continually until it is told to stop. Images are automatically given unique names. The sleep(x)
function controls the delay between captures.
sleep(2)
for filename in camera.capture_continuous('img{counter:03d}.jpg'):
print('Captured %s' % filename)
sleep(10) # capture images with a 10s delay between each shot
In order to capture OpenCV objects, an image will be captured to Python’s in-memory stream class: BytesIO
. The BytesIO will convert the stream to a numpy
array, and the program will read the array with OpenCV:
import io
import picamera
import cv2
import numpy as np
# Create the in-memory stream
stream = io.BytesIO()
with picamera.PiCamera() as camera:
time.sleep(2)
camera.capture(stream, format='jpeg')
# Construct a numpy array from the stream
data = np.fromstring(stream.getvalue(), dtype=np.uint8)
# "Decode" the image from the array, preserving colour
image = cv2.imdecode(data, 1)
# OpenCV returns an array with data in BGR order. If you want RGB instead
# use the following...
image = image[:, :, ::-1]
To avoid the losses with JPEG encoding and decoding, use the classes in the picamera.array
module. This will also potentially increase the speed of image processing.
As OpenCV images are simply numpy
arrays arranged in BGR order, the PiRGBArray
class, and simply capture with the ‘bgr’
format. Note: RGB data and BGR data are the same size and configuration, but have reversed color planes.
import picamera
import picamera.array
import cv2
time.sleep(2)
with picamera.array.PiRGBArray(camera) as stream:
camera.capture(stream, format='bgr')
# At this point the image is available as stream.array
image = stream.array
Combined with the method of capturing timelapse sequences, these 3-dimensional RGB arrays are shown by OpenCV.
import cv2
#init camera
camera.resolution = (640,480)
img = frame.array
# click ESC key to exit.
if k == 27:
camera.close()
break
There are many other ways to read video streams with OpenCV. The ones used in these examples are better suited for the next four PiCar-X tasks, such as Color Detection and Face Detection.
For more ways to use video streams, please reference: OpenCV-Python Tutorials.
