RGB LED
RGB LEDs emit light in various colors. An RGB LED packages three LEDs of red, green, and blue into a transparent or semitransparent plastic shell. It can display various colors by changing the input voltage of the three pins and superimpose them, which, according to statistics, can create 16,777,216 different colors.
RGB LEDs can be categorized into common anode and common cathode ones. In this kit, the latter is used. The common cathode, or CC, means to connect the cathodes of the three LEDs. After you connect it with GND and plug in the three pins, the LED will flash the corresponding color.
Its circuit symbol is shown as figure.
An RGB LED has 4 pins: the longest pin is the common cathode pin, which is usually connected to GND, the left pin next to the longest pin is Red, and the 2 pins on the right are Green and Blue.
Features
Color: Tri-Color (Red/Green/Blue)
Common Cathode
5mm Clear Round Lens
Forward Voltage: Red: DC 2.0 - 2.2V; Blue&Green: DC 3.0 - 3.2V (IF=20mA)
0.06 Watts DIP RGB LED
Luminance Brighter Up To +20%
Viewing Angle: 30°
Example
2.4 Colorful Light (For MicroPython User)
7.9 Fruit Piano (For MicroPython User)
2.4 - Colorful Light (For Arduino User)
2.4 Rainbow Light (For Piper Make User)
