šŸ‘‰ Ready to explore and create with us? Click [here] and join today!
7-segment DisplayĀ¶
img_7seg
A 7-segment display is an 8-shaped component which packages 7 LEDs. Each LED is called a segment - when energized, one segment forms part of a numeral to be displayed.
There are two types of pin connection: Common Cathode (CC) and Common Anode (CA). As the name suggests, a CC display has all the cathodes of the 7 LEDs connected when a CA display has all the anodes of the 7 segments connected.
In this kit, we use the Common Cathode 7-segment display, here is the electronic symbol.
img_7seg_cathode
Each of the LEDs in the display is given a positional segment with one of its connection pins led out from the rectangular plastic package. These LED pins are labeled from ā€œaā€ through to ā€œgā€ representing each individual LED. The other LED pins are connected together forming a common pin. So by forward biasing the appropriate pins of the LED segments in a particular order, some segments will brighten and others stay dim, thus showing the corresponding character on the display.
Display Codes
To help you get to know how 7-segment displays(Common Cathode) display Numbers, we have drawn the following table. Numbers are the number 0-F displayed on the 7-segment display; (DP) GFEDCBA refers to the corresponding LED set to 0 or 1, For example, 00111111 means that DP and G are set to 0, while others are set to 1. Therefore, the number 0 is displayed on the 7-segment display, while HEX Code corresponds to hexadecimal number.
Glyph CodeĀ¶
Numbers
Binary Code
Hex Code
0
00111111
0x3f
0x06
0x5b
0x4f
0x66
0x6d
0x7d
7
00000111
0x07
8
01111111
0x7f
9
01101111
0x6f
A
01110111
0x77
B
01111100
0x7c
C
00111001
0x39
D
01011110
0x5e
E
01111001
0x79
F
01110001
0x71
Example
