Lichtempfindliches Array
Dieses Programm wandelt die Messwerte eines lichtabhängigen Widerstands in eine entsprechende Anzahl beleuchteter LED-Lichter um und schafft so einen einfachen Indikator für die Helligkeit des Lichts.
ARTIKEL IN DIESEM KIT
Elite Explorer Kit
300+
Elite Explorer Kit
KOMPONENTENVORSTELLUNG
KAUF-LINK
Arduino Uno R4 WiFi
Steckbrett
KAUFEN
Jumperkabel
KAUFEN
Widerstand
KAUFEN
LED
KAUFEN
Fotowiderstand
KAUFEN
Verdrahtung
../_images/04_light_sensitive_array_bb.png
../_images/04_light_sensitive_array_schematic.png
  • Sie können die Datei 04_light_sensitive_array.ino direkt unter dem Pfad elite-explorer-kit-main\fun_project\04_light_sensitive_array öffnen.
 1/*
 2  The code reads the ambient light level through a photoresistor and lights up
 3  a certain number of LEDs based on the light level. The LEDs serve as a "light level bar."
 5  Board: Arduino Uno R4
 6  Component: Photoresistor and LED
 7*/
 8
 9// Constants for the number of LEDs and their pins
10const int NbrLEDs = 8;
11const int ledPins[] = { 5, 6, 7, 8, 9, 10, 11, 12 };
12
13// Pin for the photoresistor
14const int photocellPin = A0;
15
16// Variables to store sensor and LED level values
17int sensorValue = 0;  // value read from the sensor
18int ledLevel = 0;     // sensor value converted into LED 'bars'
19
20void setup() {
21  // Initialize all LED pins as outputs
22  for (int led = 0; led < NbrLEDs; led++) {
23    pinMode(ledPins[led], OUTPUT);
24  }
25}
26
27void loop() {
28  sensorValue = analogRead(photocellPin);              // Read the ambient light level from the photoresistor
29  ledLevel = map(sensorValue, 300, 1023, 0, NbrLEDs);  // Map the sensor value to the number of LEDs to be lit
30
31  // Update the state of each LED based on the mapped value
32  for (int led = 0; led < NbrLEDs; led++) {
33    if (led < ledLevel) {
34      digitalWrite(ledPins[led], HIGH);  // Turn ON LEDs that are below the level
35    } else {
36      digitalWrite(ledPins[led], LOW);  // Turn OFF LEDs that are above the level
37    }
38  }
39}
Wie funktioniert das?
Hier ist eine schrittweise Erklärung des Codes:
  1. Konstanten- und Variablendefinitionen:
    NbrLEDs: Definiert die Anwesenheit von 8 LEDs. ledPins[]: LEDs sind an die Arduino-Pins 5 bis 12 angeschlossen. photocellPin: Der Fotowiderstand ist an den A0-Pin des Arduino angeschlossen. sensorValue: Diese Variable speichert den vom Fotowiderstand gelesenen Wert. ledLevel: Diese Variable speichert die Anzahl der LEDs basierend auf der Umwandlung des sensorValue.
  2. setup():
    Konfiguriert die Pins 5 bis 12 als Ausgang, um die LEDs anzusteuern.
  3. loop():
    Liest den analogen Wert des Fotowiderstands vom Pin A0, typischerweise im Bereich von 0 bis 1023. Verwendet die Funktion map, um den Wert des Fotowiderstands von 300-1023 auf den Bereich 0-8 abzubilden. Das bedeutet, dass, wenn die Messung des lichtabhängigen Widerstands 300 beträgt, keine LEDs leuchten werden; wenn die Messung 1023 oder höher ist, werden alle 8 LEDs leuchten.
    Die nachfolgende for-Schleife überprüft jede LED. Wenn ihr Index kleiner als ledLevel ist, wird die LED eingeschaltet; andernfalls wird sie ausgeschaltet.
