πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
1.1.3 LED Bar Graph
Introduction
In this project, we sequentially illuminate the lights on the LED Bar Graph.
Required Components
../_images/1.1.3_led_bar_list.png
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO18
Pin 12
GPIO23
Pin 16
GPIO24
Pin 18
GPIO25
Pin 22
SPICE0
Pin 24
10
8
SPICE1
Pin 26
11
7
GPIO12
Pin 32
26
12
GPIO16
Pin 36
27
16
GPIO20
Pin 38
28
22
GPIO21
Pin 40
29
21
../_images/1.1.3_LedBarGraph_schematic.png
Experimental Procedures
Step 1: Build the circuit.
Pay attention to the direction when connecting. If you connect it backwards, it will not light up.
../_images/1.1.3_LedBarGraph_circuit.png
Step 3: Run the executable file.
sudo python3 1.1.3_LedBarGraph.py
After the code runs, you will see the LEDs on the LED bar turn on and off regularly.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import LED
from time import sleep
# Define GPIO pins where LEDs are connected
led_pins = [18, 23, 24, 25, 8, 7, 12, 16, 20, 21]
# Create LED objects for each pin
leds = [LED(pin) for pin in led_pins]
def odd_led_bar_graph():
    # Sequentially light up odd-numbered LEDs (index 0, 2, 4, etc.)
    for i in range(5):
        j = i * 2  # Calculate odd index
        leds[j].on()  # Turn on odd-numbered LED
        sleep(0.3)    # Delay for visual effect
        leds[j].off() # Turn off LED
def even_led_bar_graph():
    # Sequentially light up even-numbered LEDs (index 1, 3, 5, etc.)
    for i in range(5):
        j = i * 2 + 1  # Calculate even index
        leds[j].on()   # Turn on even-numbered LED
def all_led_bar_graph():
    # Sequentially light up all LEDs one by one
    for led in leds:
        led.on()       # Turn on LED
        led.off()      # Turn off LED
def turn_off_all_leds():
    # Turn off all LEDs at once
    for led in leds:
        led.off()
    # Main loop to cycle through LED patterns
        odd_led_bar_graph()   # Activate odd-numbered LEDs
        sleep(0.3)            # Pause between patterns
        even_led_bar_graph()  # Activate even-numbered LEDs
        all_led_bar_graph()   # Activate all LEDs
        sleep(0.3)            # Pause before restarting
    # Handle interruption (Ctrl+C) gracefully
    turn_off_all_leds()      # Ensure all LEDs are turned off on exit
Code Explanation
  1. These lines import the necessary classes and functions. LED from gpiozero for LED control and sleep from time for delays.
  2. The led_pins list contains the GPIO pin numbers. leds is a list of LED objects, each corresponding to a pin in led_pins.
  3. Let the LED on the odd digit of the LED Bar Graph light on in turn.
        for i in range(5):
  4. Make the LED on the even digit of the LED Bar Graph light on in turn.
        for i in range(5):
  5. Let the LED on the LED Bar Graph light on one by one.
        for led in leds:
  6. The while True loop continuously cycles through the LED patterns. The except block handles a KeyboardInterrupt (Ctrl+C), ensuring all LEDs are turned off on exit.
