šŸ‘‰ Ready to explore and create with us? Click [here] and join today!
1.2.2 Passive Buzzer
Introduction
In this lesson, we will learn how to make a passive buzzer play music.
Components
../_images/list_1.2.21.png
Schematic Diagram
In this experiment, a passive buzzer, a PNP transistor and a 1k resistor are used between the base of the transistor and GPIO to protect the transistor.
When GPIO17 is given different frequencies, the passive buzzer will emit different sounds; in this way, the buzzer plays music.
../_images/image3331.png
Experimental Procedures
Step 1: Build the circuit.
../_images/image1061.png
Step 2: Change directory.
cd ~/davinci-kit-for-raspberry-pi/c/1.2.2/
Step 3: Compile.
gcc 1.2.2_PassiveBuzzer.c -lwiringPi
Step 4: Run.
The code run, the buzzer plays a piece of music.
#include <wiringPi.h>
#include <softTone.h>
#include <stdio.h>
#define BuzPin    0
#define  CL1  131
#define  CL2  147
#define  CL3  165
#define  CL4  175
#define  CL5  196
#define  CL6  221
#define  CL7  248
#define  CM1  262
#define  CM2  294
#define  CM3  330
#define  CM4  350
#define  CM5  393
#define  CM6  441
#define  CM7  495
#define  CH1  525
#define  CH2  589
#define  CH3  661
#define  CH4  700
#define  CH5  786
#define  CH6  882
#define  CH7  990
int song_1[] = {CM3,CM5,CM6,CM3,CM2,CM3,CM5,CM6,CH1,CM6,CM5,CM1,CM3,CM2,
                CM2,CM3,CM5,CM2,CM3,CM3,CL6,CL6,CL6,CM1,CM2,CM3,CM2,CL7,
                CL6,CM1,CL5};
int beat_1[] = {1,1,3,1,1,3,1,1,1,1,1,1,1,1,3,1,1,3,1,1,1,1,1,1,1,2,1,1,
                1,1,1,1,1,1,3};
int song_2[] = {CM1,CM1,CM1,CL5,CM3,CM3,CM3,CM1,CM1,CM3,CM5,CM5,CM4,CM3,CM2,
                CM2,CM3,CM4,CM4,CM3,CM2,CM3,CM1,CM1,CM3,CM2,CL5,CL7,CM2,CM1
int beat_2[] = {1,1,1,3,1,1,1,3,1,1,1,1,1,1,3,1,1,1,2,1,1,1,3,1,1,1,3,3,2,3};
int main(void)
    int i, j;
    if(softToneCreate(BuzPin) == -1){
        printf("setup softTone failed !");
        printf("music is being played...\n");
        delay(100);
        for(i=0;i<sizeof(song_1)/4;i++){
            softToneWrite(BuzPin, song_1[i]);
            delay(beat_1[i] * 500);
        for(i=0;i<sizeof(song_2)/4;i++){
            softToneWrite(BuzPin, song_2[i]);
            delay(beat_2[i] * 500);
Code Explanation
#define  CL1  131
#define  CL2  147
#define  CL3  165
#define  CL4  175
#define  CL5  196
#define  CL6  221
#define  CL7  248
#define  CM1  262
#define  CM2  294
These frequencies of each note are as shown. CL refers to low note, CM middle note, CH high note, 1-7 correspond to the notes C, D, E, F, G, A, B.
                CL6,CM1,CL5};
                1,1,1,1,1,1,3};
The array, song_1[] stores a musicalĀ score of a song in which beat_1[] refers to the beat of each note in the song (0.5s for each beat).
This creates a software controlled tone pin. You can use any GPIO pin and the pin numbering will be that of theĀ wiringPiSetup() function you used. The return value is 0 for success. Anything else and you should check the globalĀ errnovariable to see what went wrong.
Employ a for statement to play song_1.
In the judgment condition, i<sizeof(song_1)/4ļ¼Œā€œdevide by 4ā€ is used because the array song_1[] is an array of the data type of integer, and each element takes up four bytes.
The number of elements in song_1 (the number of musical notes) is gotten by deviding sizeof(song_4) by 4.
To enable each note to play for beat * 500ms, the function delay(beat_1[i] * 500) is called.
The prototype of softToneWrite(BuzPin, song_1[i]):
void softToneWrite (int pin, int freq);
This updates the tone frequency value on the given pin. The tone does not stop playing until you set the frequency to 0.
