.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
š Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
1.2.2 Passive Buzzer
In this lesson, we will learn how to make a passive buzzer play music.
Components
.. image:: img/list_1.2.2.png
Schematic Diagram
In this experiment, a passive buzzer, a PNP transistor and a 1k resistor
are used between the base of the transistor and GPIO to protect the
transistor.
When GPIO17 is given different frequencies, the passive buzzer will emit
different sounds; in this way, the buzzer plays music.
.. image:: img/image333.png
Experimental Procedures
**Step 1**: Build the circuit.
.. image:: img/image106.png
:width: 800
**Step 2**: Change directory.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/1.2.2/
**Step 3**: Compile.
.. raw:: html
.. code-block::
gcc 1.2.2_PassiveBuzzer.c -lwiringPi
**Step 4**: Run.
.. raw:: html
.. code-block::
The code run, the buzzer plays a piece of music.
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi_pi5`.
**Code**
.. code-block:: c
#include
#include
#include
#define BuzPin 0
#define CL1 131
#define CL2 147
#define CL3 165
#define CL4 175
#define CL5 196
#define CL6 221
#define CL7 248
#define CM1 262
#define CM2 294
#define CM3 330
#define CM4 350
#define CM5 393
#define CM6 441
#define CM7 495
#define CH1 525
#define CH2 589
#define CH3 661
#define CH4 700
#define CH5 786
#define CH6 882
#define CH7 990
int song_1[] = {CM3,CM5,CM6,CM3,CM2,CM3,CM5,CM6,CH1,CM6,CM5,CM1,CM3,CM2,
CM2,CM3,CM5,CM2,CM3,CM3,CL6,CL6,CL6,CM1,CM2,CM3,CM2,CL7,
CL6,CM1,CL5};
int beat_1[] = {1,1,3,1,1,3,1,1,1,1,1,1,1,1,3,1,1,3,1,1,1,1,1,1,1,2,1,1,
1,1,1,1,1,1,3};
int song_2[] = {CM1,CM1,CM1,CL5,CM3,CM3,CM3,CM1,CM1,CM3,CM5,CM5,CM4,CM3,CM2,
CM2,CM3,CM4,CM4,CM3,CM2,CM3,CM1,CM1,CM3,CM2,CL5,CL7,CM2,CM1
int beat_2[] = {1,1,1,3,1,1,1,3,1,1,1,1,1,1,3,1,1,1,2,1,1,1,3,1,1,1,3,3,2,3};
int main(void)
int i, j;
if(softToneCreate(BuzPin) == -1){
printf("setup softTone failed !");
printf("music is being played...\n");
delay(100);
for(i=0;i
