πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
9. Red Object Tracking with Pan-Tilt Camera
Object tracking combined with mechanical control forms the foundation of many robotics and computer vision applications. In this chapter, we will create a system that detects red objects in real-time and controls pan-tilt servos to keep the object centered in the camera view.
This extends basic color detection into an active tracking system that can follow moving objects autonomously.
Pan-tilt camera tracking system overview
1. Objective and Approach
  • Use Picamera2 to capture real-time video frames
  • Detect red objects using HSV color space and morphological filtering
  • Implement simple 4-direction tracking algorithm based on object position
  • Control pan and tilt servos to keep the object centered
  • Display real-time debugging information and tracking status
  • Provide adjustable parameters for fine-tuning tracking behavior
2. Run the Code
Important
Before you start, make sure:
  • The pan-tilt is assembled
  • You can access the Raspberry Pi desktop
  • The code package is installed
  • Fusion HAT+ is installed and configured
  • OpenCV is installed
For detailed instructions, see 0. Setup OpenCV.
  1. Open the terminal and enter the following command:
    cd ~/ai-lab-kit/opencv_python
    python3 cv_9_track_color.py
3. Execution Result
When running successfully, you should see:
1. OpenCV Window:
  • β€œRed Object Tracking”: Shows the camera feed with tracking overlay
2. Visual elements in the tracking window:
  • Yellow crosshair at frame center
  • Blue rectangle showing the deadzone (no-movement zone)
  • Red circle marking the detected object center
  • Green line connecting object to frame center
  • Real-time information overlay:
    • Object position coordinates
    • Current servo angles
    • Tracking mode (Simple 4-Direction)
    • Movement step and deadzone settings
3. Console output:
  • FPS (frames per second)
  • Current servo positions
  • Object detection status
  • Movement step adjustments
4. Servo behavior:
  • Servos will move in fixed steps to keep red objects centered
  • No movement when object is within the deadzone
  • Servos return to center position when β€˜r’ key is pressed
Controls:
  • Press β€˜q’ to quit the program
  • Press β€˜r’ to reset servos to center position
  • Press β€˜+’ to increase movement speed
  • Press β€˜-’ to decrease movement speed
4. Complete Code
Below is the complete Python program for red object tracking:
import cv2
import numpy as np
from fusion_hat.servo import Servo
# ========== SERVO SETTINGS ==========
# Servo channels
PAN_CHANNEL = 2    # Horizontal servo
TILT_CHANNEL = 3   # Vertical servo
# Servo angle limits (adjust according to your hardware)
PAN_MIN = -90      # Maximum left rotation
PAN_MAX = 90       # Maximum right rotation
TILT_MIN = -45     # Maximum down rotation
TILT_MAX = 45      # Maximum up rotation
# Initial position (center)
PAN_CENTER = 0
TILT_CENTER = 0
# ========== CAMERA SETTINGS ==========
FRAME_WIDTH = 640
FRAME_HEIGHT = 480
CENTER_X = FRAME_WIDTH // 2
CENTER_Y = FRAME_HEIGHT // 2
# ========== COLOR DETECTION SETTINGS ==========
# Red color range in HSV (two ranges for red)
LOWER_RED1 = np.array([0, 100, 80])     # Lower range for red
UPPER_RED1 = np.array([10, 255, 255])   # Upper range for red
LOWER_RED2 = np.array([170, 100, 80])   # Lower range for red (wrap-around)
UPPER_RED2 = np.array([180, 255, 255])  # Upper range for red (wrap-around)
# Morphology kernel for noise removal
KERNEL = cv2.getStructuringElement(cv2.MORPH_ELLIPSE, (5, 5))
# Minimum contour area to consider (adjust based on object size)
MIN_CONTOUR_AREA = 500
# ========== TRACKING SETTINGS ==========
# Deadzone around center (pixels) - no movement inside this zone
DEADZONE_X = 50    # Horizontal deadzone
DEADZONE_Y = 50    # Vertical deadzone
# Movement step size in degrees (how much to move each frame)
MOVE_STEP = 2      # Degrees to move per adjustment
# ========== INITIALIZE HARDWARE ==========
print("Initializing Red Object Tracking System...")
# Initialize servos
print("Setting up servos...")
pan_servo = Servo(PAN_CHANNEL)
tilt_servo = Servo(TILT_CHANNEL)
# Center the servos initially
print("Centering servos...")
pan_servo.angle(PAN_CENTER)
tilt_servo.angle(TILT_CENTER)
time.sleep(1)  # Wait for servos to move to center
# Current servo positions
current_pan = PAN_CENTER
current_tilt = TILT_CENTER
# Initialize camera
print("Setting up camera...")
picam2 = Picamera2()
# Configure camera for OpenCV
config = picam2.create_preview_configuration(
    main={"size": (FRAME_WIDTH, FRAME_HEIGHT), "format": "XRGB8888"}
picam2.configure(config)
picam2.start()
print("Camera started. Looking for red objects...")
print("Press 'q' to quit the program")
print("-" * 50)
def simple_tracking(x, y):
    Simple 4-direction tracking algorithm
    Args:
        x: Object x-coordinate (None if not found)
        y: Object y-coordinate (None if not found)
    Returns:
        pan_move, tilt_move: Degrees to move each servo (+/-)
    # If no object detected, don't move
    if x is None or y is None:
        return 0, 0
    pan_move = 0
    tilt_move = 0
    # Check if object is left of center (outside deadzone)
    if x < CENTER_X - DEADZONE_X:
        # Object is left, move camera right (positive pan)
        pan_move = MOVE_STEP
    # Check if object is right of center (outside deadzone)
    elif x > CENTER_X + DEADZONE_X:
        # Object is right, move camera left (negative pan)
        pan_move = -MOVE_STEP
    # Check if object is above center (outside deadzone)
    if y < CENTER_Y - DEADZONE_Y:
        # Object is up, move camera down (negative tilt)
        tilt_move = -MOVE_STEP
    # Check if object is below center (outside deadzone)
    elif y > CENTER_Y + DEADZONE_Y:
        # Object is down, move camera up (positive tilt)
        tilt_move = MOVE_STEP
    return pan_move, tilt_move
def update_servo_position(pan_move, tilt_move):
    Update servo positions with limits checking
    Args:
        pan_move: Degrees to move pan servo (+/-)
        tilt_move: Degrees to move tilt servo (+/-)
    Returns:
        current_pan, current_tilt: New servo positions
    global current_pan, current_tilt
    # Calculate new positions
    new_pan = current_pan + pan_move
    new_tilt = current_tilt + tilt_move
    # Apply angle limits to prevent hardware damage
    new_pan = max(min(new_pan, PAN_MAX), PAN_MIN)
    new_tilt = max(min(new_tilt, TILT_MAX), TILT_MIN)
    # Move servos only if position changed
    if new_pan != current_pan:
        pan_servo.angle(new_pan)
        current_pan = new_pan
    if new_tilt != current_tilt:
        tilt_servo.angle(new_tilt)
        current_tilt = new_tilt
    return current_pan, current_tilt
def find_red_object(frame):
    Detect red object in frame using HSV color space
    Args:
        frame: Input BGR image frame
    Returns:
        center_x, center_y: Coordinates of largest red object, or (None, None)
        mask: Binary mask showing detected red areas
    # Convert BGR to HSV color space (better for color detection)
    hsv = cv2.cvtColor(frame, cv2.COLOR_BGR2HSV)
    # Create masks for red color (red wraps around 0 in HSV)
    mask1 = cv2.inRange(hsv, LOWER_RED1, UPPER_RED1)   # Lower red range
    mask2 = cv2.inRange(hsv, LOWER_RED2, UPPER_RED2)   # Upper red range
    mask = cv2.bitwise_or(mask1, mask2)                # Combine both ranges
    # Apply morphological operations to clean up noise
    mask = cv2.morphologyEx(mask, cv2.MORPH_OPEN, KERNEL, iterations=1)
    mask = cv2.morphologyEx(mask, cv2.MORPH_CLOSE, KERNEL, iterations=2)
    # Find contours in the mask
    contours, _ = cv2.findContours(mask, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_SIMPLE)
    # Return if no contours found
    if not contours:
        return None, None, mask
    # Find the largest contour (assume it's our target)
    largest_contour = max(contours, key=cv2.contourArea)
    area = cv2.contourArea(largest_contour)
    # Filter by minimum area to ignore small noise
    if area < MIN_CONTOUR_AREA:
    # Calculate center of the contour using image moments
    M = cv2.moments(largest_contour)
    if M["m00"] == 0:  # Prevent division by zero
    center_x = int(M["m10"] / M["m00"])
    center_y = int(M["m01"] / M["m00"])
    return center_x, center_y, mask
def draw_debug_info(frame, object_x, object_y, mask, pan_angle, tilt_angle):
    Draw debugging information on the frame for visualization
    Args:
        frame: Frame to draw on
        object_x, object_y: Object coordinates
        mask: Detection mask
        pan_angle, tilt_angle: Current servo angles
    Returns:
        frame: Frame with debug drawings
    # Draw center crosshair
    cv2.line(frame, (CENTER_X - 20, CENTER_Y), (CENTER_X + 20, CENTER_Y), (0, 255, 255), 2)
    cv2.line(frame, (CENTER_X, CENTER_Y - 20), (CENTER_X, CENTER_Y + 20), (0, 255, 255), 2)
    cv2.circle(frame, (CENTER_X, CENTER_Y), 5, (0, 255, 255), -1)
    # Draw deadzone rectangle
    cv2.rectangle(frame,
                 (CENTER_X - DEADZONE_X, CENTER_Y - DEADZONE_Y),
                 (CENTER_X + DEADZONE_X, CENTER_Y + DEADZONE_Y),
                 (255, 255, 0), 1)
    # Draw object center if detected
    if object_x is not None and object_y is not None:
        cv2.circle(frame, (object_x, object_y), 10, (0, 0, 255), -1)
        cv2.line(frame, (CENTER_X, CENTER_Y), (object_x, object_y), (0, 255, 0), 2)
        # Display position information
        pos_text = f"Position: ({object_x}, {object_y})"
        cv2.putText(frame, pos_text, (10, 30),
                   cv2.FONT_HERSHEY_SIMPLEX, 0.6, (0, 255, 0), 2)
    # Display servo angles
    angle_text = f"Pan: {pan_angle:+03.0f}, Tilt: {tilt_angle:+03.0f}"
    cv2.putText(frame, angle_text, (10, 60),
               cv2.FONT_HERSHEY_SIMPLEX, 0.6, (255, 255, 0), 2)
    # Display tracking mode
    cv2.putText(frame, "Mode: Simple 4-Direction", (10, 90),
               cv2.FONT_HERSHEY_SIMPLEX, 0.6, (255, 255, 255), 2)
    # Display movement step
    step_text = f"Step: {MOVE_STEP}, Deadzone: {DEADZONE_X}px"
    cv2.putText(frame, step_text, (10, 120),
    # Draw quit instruction
    cv2.putText(frame, "Press 'q' to quit, 'r' to reset", (10, FRAME_HEIGHT - 10),
               cv2.FONT_HERSHEY_SIMPLEX, 0.5, (255, 255, 255), 1)
    return frame
def cleanup():
    Clean up resources before exiting
    print("\nCleaning up...")
    # Center servos before stopping
    time.sleep(0.5)
    # Stop camera
    print("Stopping camera...")
    picam2.stop()
    # Close OpenCV windows
    cv2.destroyAllWindows()
    print("System shutdown complete.")
# ========== MAIN LOOP ==========
def main():
    Main tracking loop
    frame_count = 0
    start_time = time.time()
    global MOVE_STEP
            # Capture frame from camera
            frame_bgra = picam2.capture_array()
            frame_bgr = cv2.cvtColor(frame_bgra, cv2.COLOR_BGRA2BGR)
            # Find red object in frame
            obj_x, obj_y, mask = find_red_object(frame_bgr)
            # Use simple tracking algorithm to determine movement
            pan_move, tilt_move = simple_tracking(obj_x, obj_y)
            # Update servo positions
            pan_angle, tilt_angle = update_servo_position(pan_move, tilt_move)
            # Draw debugging information
            frame_display = draw_debug_info(frame_bgr, obj_x, obj_y, mask, pan_angle, tilt_angle)
            # Display frames
            cv2.imshow("Red Object Tracking", frame_display)
            # Calculate and display FPS every 30 frames
            frame_count += 1
            if frame_count % 30 == 0:
                elapsed_time = time.time() - start_time
                fps = frame_count / elapsed_time
                print(f"FPS: {fps:.1f} | Pan: {pan_angle:+03.0f}Β° | Tilt: {tilt_angle:+03.0f}Β° | "
                      f"Object: {'Found' if obj_x else 'Not found'}")
            # Check for user input
            key = cv2.waitKey(1) & 0xFF
            if key == ord('q'):
                print("\nQuit command received.")
                break
            elif key == ord('r'):
                # Reset to center position
                print("Resetting to center...")
                time.sleep(0.5)
            elif key == ord('+'):
                # Increase movement speed
                MOVE_STEP = min(MOVE_STEP + 0.5, 5)
                print(f"Movement step increased to {MOVE_STEP}Β°")
            elif key == ord('-'):
                # Decrease movement speed
                MOVE_STEP = max(MOVE_STEP - 0.5, 0.5)
                print(f"Movement step decreased to {MOVE_STEP}Β°")
        print("\nProgram interrupted.")
    finally:
        cleanup()
# ========== PROGRAM START ==========
if __name__ == "__main__":
    print("=" * 60)
    print("RED OBJECT TRACKING WITH PAN-TILT CAMERA")
    print("=" * 60)
    print("System will:")
    print("1. Detect red objects using OpenCV")
    print("2. Move servos in 4 directions to keep object centered")
    print("3. Display tracking information")
    print("\nControls:")
    print("  Press 'q' to quit")
    print("  Press 'r' to reset servos to center")
    print("  Press '+' to increase movement speed")
    print("  Press '-' to decrease movement speed")
    print("\nTracking Logic:")
    print(f"  Deadzone: {DEADZONE_X}px around center (no movement)")
    print(f"  Movement: {MOVE_STEP}Β° per adjustment")
    print("  Left object β†’ Move right (+pan)")
    print("  Right object β†’ Move left (-pan)")
    print("  Up object β†’ Move down (-tilt)")
    print("  Down object β†’ Move up (+tilt)")
    print("=" * 60)
    main()
5. Code Explanation
  1. simple_tracking(x, y)
    This function decides how the servos should move based on the detected object position.
    • If no object is detected (x or y is None), it returns (0, 0) (no movement).
    • If the object is outside the deadzone, it returns a small movement step:
      • Object left β†’ pan_move = +MOVE_STEP
      • Object right β†’ pan_move = -MOVE_STEP
      • Object up β†’ tilt_move = -MOVE_STEP
      • Object down β†’ tilt_move = +MOVE_STEP
    The deadzone prevents the camera from shaking when the object is already near the center.
  2. update_servo_position(pan_move, tilt_move)
    This function updates the pan/tilt servo angles safely.
    • Adds the movement step to the current servo angles.
    • Clamps the angles to safe limits (PAN_MIN/PAN_MAX and TILT_MIN/TILT_MAX).
    • Sends servo commands only when the angle actually changes.
    This protects the hardware from over-rotation.
  3. find_red_object(frame)
    This function detects the largest red object in the camera frame.
    Main steps:
    • Converts the frame from BGR to HSV.
    • Creates a binary mask for red pixels using two HSV ranges.
    • Cleans the mask using morphology (OPEN + CLOSE).
    • Finds contours and selects the largest one.
    • Filters out small blobs using MIN_CONTOUR_AREA.
    • Uses image moments to compute the object center.
    It returns:
    • center_x, center_y: the object center position (or None, None)
    • mask: the binary mask showing red areas
  4. draw_debug_info(frame, object_x, object_y, mask, pan_angle, tilt_angle)
    This function draws helpful tracking information on the video frame, including:
    • Center crosshair
    • Deadzone rectangle
    • Detected object position
    • Servo angles (pan and tilt)
    • Tracking mode and step size
    • Key instructions
    This makes it easy to see how the tracker is working.
  5. cleanup()
    This function safely shuts down the system before exiting.
    • Moves servos back to the center position.
    • Stops the camera.
    • Closes all OpenCV windows.
    This prevents the camera from being left in a strange position.
  6. main()
    This is the main tracking loop.
    Each iteration does:
    • Capture a camera frame.
    • Detect the red object.
    • Decide how to move the servos.
    • Update servo angles.
    • Draw debug information.
    • Display the result window.
    It also supports runtime controls:
    • q to quit
    • r to reset servos
    • + / - to adjust tracking speed
    The program always calls cleanup() in the finally block to ensure safe shutdown.
6. Key Parameters and Tuning
  1. Color Detection Parameters
    # HSV thresholds for red detection
    LOWER_RED1 = np.array([0, 100, 80])     # [Hue, Saturation, Value]
    # Minimum object size
    Tuning tips:
    • Adjust Hue values for different colors
    • Increase Saturation/Value minimums in bright environments
    • Adjust MIN_CONTOUR_AREA based on expected object size
  2. Tracking Parameters
    # Deadzone size (pixels)
    DEADZONE_X = 50    # Larger = less jitter, but less precision
    DEADZONE_Y = 50
    # Movement step size (degrees)
    MOVE_STEP = 2      # Larger = faster tracking, but may overshoot
    Tuning tips:
    • Start with larger deadzone (50-100px) for stable operation
    • Adjust MOVE_STEP based on tracking requirements (0.5-5Β°)
    • Use β€˜+’ and β€˜-’ keys to adjust speed during runtime
  3. Servo Parameters
    # Servo limits (calibrate for your hardware)
    Calibrate these values for your specific hardware to prevent damage.
7. Common Issues and Troubleshooting
  • Servo Not Moving
    • Cause: Object within deadzone or MIN_CONTOUR_AREA too high
    • Solution: Check object position, reduce MIN_CONTOUR_AREA, or decrease deadzone
  • Servo Movement Too Slow
    • Cause: MOVE_STEP too small
    • Solution: Press β€˜+’ key to increase movement speed
  • Servo Movement Too Jerky
    • Cause: MOVE_STEP too large
    • Solution: Press β€˜-’ key to decrease movement speed
  • False Object Detection
    • Cause: HSV thresholds too broad or lighting issues
    • Solution: Adjust HSV ranges, improve lighting, increase MIN_CONTOUR_AREA
  • Low FPS (Below 10 FPS)
    • Cause: Processing overload or camera settings
    • Solution: Reduce frame resolution, simplify debug drawing
8. Extensions and Advanced Features
  1. Multiple Object Tracking
    # Instead of taking the largest contour:
    for contour in contours:
        if cv2.contourArea(contour) > MIN_CONTOUR_AREA:
            # Track multiple objects
  2. Return to Proportional Control
    # Re-implement proportional control if desired
    KP_PAN = 0.3
    pan_move = -x_error * KP_PAN / CENTER_X
  3. Object Size-Based Speed Adjustment
    # Adjust movement speed based on object size
    object_size = cv2.contourArea(largest_contour)
    if object_size > 1000:  # Large object
        adjusted_step = MOVE_STEP * 0.5  # Move slower
    else:  # Small object
        adjusted_step = MOVE_STEP * 1.5  # Move faster
  4. Logging and Data Recording
    # Record tracking data for analysis
    with open('tracking_log.csv', 'a') as f:
        f.write(f"{time.time()},{obj_x},{obj_y},{pan_angle},{tilt_angle}\n")
  5. Network Streaming
    # Stream video over network
    import socket
    # Add network streaming code
9. Learning Outcomes
After completing this project, you should understand:
  1. Computer Vision: Real-time color detection and object tracking
  2. Control Systems: Simple 4-direction tracking algorithm implementation
  3. Hardware Integration: Interfacing cameras and servos with Raspberry Pi
  4. Interactive Control: Real-time parameter adjustment during operation
  5. System Design: Simplified tracking system architecture
This project provides a foundation for more advanced applications like face tracking, autonomous navigation, and industrial automation systems. The simplified 4-direction approach makes it easier to understand and modify for different applications.
